WR400 starts fine. Won't stay running.
1 reply to this topic
  • James Jiranek
Posted April 02, 2006 - 04:39 PM
I adjusted the idle but, it still quits after idling after about 20 seconds. Runs great! I just want it to be able to idle. Any ideas?
  • Numskull
Posted April 02, 2006 - 06:16 PM
Ive read good things about the Eldebrock, swap it out and forget about it.
Might want to clean your air filter. other wise you'll have to rebuild your carb and visually inspect everything, clean thoroughly, set everything correct, and check for air leaks.
