Wash out
3 replies to this topic
  • YZRob
Posted March 29, 2006 - 05:35 AM
I have a 2000 YZ426 and am a VET C Hare scramble racer. I am having a problem with the front end washing out in the turns. I have reset my front forks with lighter oil and tried the adjustments in all positions.(compression and rebound)
Any suggestions? I am at a loss here. waisting to much time picking the bike back up after going down in the turns.
Rob
  • big t
Posted March 29, 2006 - 05:49 AM
Have you played with the fork height in the triple clamps? What tire are running on the front?
Posted March 29, 2006 - 08:20 AM
Some of the things that can encourage this kind of behavior are:
> Too much rear sag (increases rake and trail)
(decrease sag to the right spec, increase the rear spring rate if too soft, raise fork tubes in clamps 5-10mm)
> Not sitting far enough forward in turns
(move forward, extend inside leg forward for additional front weight in corners)
> Bike too vertical, forcing front tire to steer, rather than roll, around the turn
(lean the bike inside of your body centerline)
> Wrong tire for your soil type.
(most YZF's came with D739's, and lots of guys replace with the same thing they had. 739's work well only on hard pack surfaces.
> Too much rebound damping.
The YZ426 also has a device built in that will, in most cases, immediately stop the front tire from pushing; the throttle. If you bust it open about 3/4 of the way, the push will usually stop. Takes some time to learn to do this, though.
  • YZRob
Posted March 30, 2006 - 04:49 AM
Have not played with fork height, when I had them off the bike,I put them back to the same measurement. Am running a maxi cross front and rear, they have always been great on other bikes I've had.I had not thought about the sag on the rear, may have to play with this a bit. As for the throttle, it's hard to craack it to far when riding tight woods :thumbsup: Will try sitting more forward next time I go out.
What do you guys think about off set axles or triple clamps?
Thanks for the info.
  • Hot  36 replies
  • 9 replies
  • Hot  50 replies
