Bar Bends for my 06
13 replies to this topic
  • yzvet
Posted March 28, 2006 - 11:40 AM
I had my first ride on the 06. I can't begin to say how awesome this bike is in every way. I need to change the bars though. I'm 6 foot and feel alittle cramped. I was looking at Pro Taper but I can't find any chart that shows what each bend measures. How they heck am I supposed to know the differance between a Windam bend and a YZ High bend?
Do any of you now where they are hiding a size chart for Pro Tapers? :thumbsup:
  • RoughR1der
Posted March 28, 2006 - 03:39 PM
http://www.protaper....eastonbars.html
There is a "Load Chart" button for all their bars under "Products" > "Handlebars" > <type>
http://www.protaper....ontourbars.html
  • cowboyona426
Posted March 28, 2006 - 08:23 PM
I'd go with the Windham and 10mm risers, I'm 6'2" and the setup works great for me.
  • creamcheese
Posted March 28, 2006 - 08:26 PM
www.zeta-racing.com
  • Drfletcherdc
Posted March 28, 2006 - 09:59 PM
I have tried 4 different bends for the bike. The stock Pro Tapers are just too low, but I liked the way that they feel. I tried a Renthal Ricky Carmichael high bend but they were way too high. The next one I tried were the Renthal Twin Wall Emig bend but I still wasn't quite satisfied yet. I just put on the Pro Taper Windham Mx bend and they seem to have the best feel. I would save the money and just get the Windham bend or something about 99 mm high.
  • Idaho_Stas
Posted March 29, 2006 - 09:23 AM
I agree w/ other posters. I went with the Windham bend first. Still wasn't quite high enough for my taste (I'm 6')... so I added a 10mm riser as well. On a track, I can do without the 10mm, but for Desert/Trail riding, I like the additional height.
You are right though... the bike ROCKS! :thumbsup:
After you get the handlebar height figured out, you'll also want to swap out the front tire. Plenty of strings on here on that topic.
  • nysurfsf
Posted April 03, 2006 - 11:53 AM
where do i get the 10mm risers?
anyone got a link?
I like the stock bars (flat bend)
i run bridgestone 401A front and a 402A rear tires. expensive but worth it. make sure to look for the "A's" as they are in limited release. wider tire.
  • Troutman
Posted April 03, 2006 - 02:53 PM
I to like the stock bars but they are to low. Try before you buy.
http://www.thumperta...ad.php?t=350784
  • aedwards07
Posted April 04, 2006 - 12:17 PM
I like the Renthal Whindham bend in the twinwall variety.
  • xnofriendsx
Posted April 04, 2006 - 03:06 PM
I ride a 2002 YZF426, but maybe this info can help a bit.
I am 6ft 5in and 235lbs. I "had" 10mm risers with Renthal Twinwall (Windham Bend). I think they are 92mm.
This was just too short for me. I have even dropped my pegs with the foot peg mod on the 426.
So now i am trying the Renthal Fatbar RC High (114mm).
Hopefully this is a bit better. I just feel like I am going to fly over the bars sometimes cause when i stand up over whoops, etc, i just am hunched over too far.
Anyways..
Hope this info helps. If not, maybe someone else.
Brian
  • Idaho_Stas
Posted April 04, 2006 - 03:54 PM
anyone got a link?
TT member Coop39 (or Coop37 maybe?) sold me a pair. He had them in 10mm and 15mm sizes. Problem w/ going the 15mm route is that I believe you will need bar mounts with longer bolts. I'm running mine with 10mm with no washer and I can get 4 - 5 threads on in the nut.
If I knew how to post photos, I'd post one. When I bought mine from Coop, he sent me a photo of the install. Pretty slick and clean.
  • cowboyona426
Posted April 05, 2006 - 08:08 PM
FYI the 15's don't work with stock mounts... even without the washer there isn't enough stud poking through to get the nut started. I wanted the 15's but had to have mine shaved down to 10's in order to make them work.
  • DPW
Posted April 05, 2006 - 09:01 PM
http://www.allthings...um/DSCN0007.JPG
  • Idaho_Stas
Posted April 06, 2006 - 02:27 PM
That's the one... :thumbsup:
