IMS tank leak problem
4 replies to this topic
  • Ga426owner
Posted October 08, 2001 - 05:10 AM
Anyone using the WR IMS Tank? Mine seems to leak gas at the fill hole, no matter how tight the cap is on....
Any ideas on a fix will be appreciated. Thanks
  • MojaveMutt
Posted October 08, 2001 - 07:54 AM
I had the same problem. IMS replaced the tank without problem. A tank that does that has a defect just below the threads for the cap. This area on my tank was concave instead of flat. This defect would never allow the cap to stop leaking.
Glenn
  • dgrimmy
Posted October 08, 2001 - 09:53 PM
I had the same problem, there was some air bubbles on the threads from the molding process and it chipped in a couple places, it'd leak even if I torqued it so tight I could barely get it off. They sent a replacement w/out a problem.
  • Ga426owner
Posted October 10, 2001 - 03:21 PM
Guys, thanks sounds like great craftmanship. I will be contacting them tomarrow. I wonder if they will replace my Tank graphics? Not!
  • YAMAKAZE
Posted October 12, 2001 - 11:04 AM
I think we need to call David a "WHAAAMBULANCE" , Come on Rich Boy, Bend the corner on that wallet a little bit......
Good Luck Tomorrow...I hear the WX just might hold out.....
Bonzai Posted Image
