mikuni jetting
2 replies to this topic
  • Tom81
Posted March 26, 2006 - 09:52 AM
Hi
In a few days i will recieve a new mikuni carb for my 650R instead of the stock keihin.
I have uncorked the bike, put on a twin-air airfilter, removed backfire screen, drilled six 2cm holes in the airfiltercover. and the exhaust is a fully open White Brothers E-2.
Now I need good advice about jetting the carb, please help :thumbsup:
  • BWB63
Posted March 26, 2006 - 12:32 PM
My Mikuni TM40 Carburetor -> 140 main, 27.5 pilot, 1.2 air jet, Y-4 needle jet, 4th pos. on the 90JY1 needle
The air jet is the jet that causes a lot of problems. It is usually a 0.9 or 1.o used for a Harley but, our bike needs a 1.2 air jet.
Most of the TM 40's have a Y-8 or Y-6 needle jet but, I found the Y-4 to work best for me. 140 main and 27.5 pilot should be to rich for most but, my bike is modified.
  • snaggleXR650
Posted March 26, 2006 - 01:38 PM
Hello,
I'm at sea level, (Florida) with a stock uncorked bike. I run a 25 pilot, 1.2 air jet, and a 140-145 main (haven't fine tuned the main jet, I just know it's rich enough). With a free flowing exhaust I have better luck with the y-6 needle jet and the 9DJY4 needle 3rd clip. With a quieter, more restrictive exhaust I use the y-4 needle jet.
My TM40 was shipped VERY lean, so lean the bike wouldn't even start. Be aware how your's is jetted, don't just bolt it on and run. If you are at 1000ft+ elevation then you will probably want to go with a 20 or 22.5 pilot and maybe a 135-140 main jet and the y-4 needle jet.
Be sure to check the air jet (in the mouth of the carb), you will want a 1.1 or 1.2 in there. Mine shipped with a 1.0 air jet. Good luck.
Honda XR650L 2016
  • 0 reviews
  • 4 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
