Two fork oil questions.
3 replies to this topic
  • slowxr
Posted March 25, 2006 - 03:46 PM
Do you measure fork oil height with the long tube inserted in the damping rod(with everything collapsed)? I noticed there is a 10mm difference depending on if it's in or out.
And what's the fork oil height range? I'm at 120mm. Is it safe to lower it to 125-130mm?
  • Jon-D
Posted March 25, 2006 - 04:20 PM
The damping rod should be removed and while measuring and the fork tube should be collapse. If your looking for a plusher ride and your forks are not bottoming out, lowering the oil height to 130 should be fine.
  • BWB63
Posted March 25, 2006 - 07:59 PM
Everything in with the nut on, only the spring out. It's in the shop Manuel.
http://xr650r.borynack.com/
  • anttismo
Posted March 26, 2006 - 02:52 AM
I've run as low as 80mm. I've been waiting for kaiser shoze to get me, but haven't seen him yet :thumbsup:
  • Hot  186 replies
  • Hot  35 replies
Washington
  • Hot  32 replies
  • Hot  60 replies
  • 4 replies
