2002 wr426 jetting
2 replies to this topic
  • slkerns1
Posted March 23, 2006 - 06:08 AM
i have a 2002 wr 426, that i am trying to tune. here are the things that i have done so far. i removed throttle stop, removed air box lid, removed baffle in exhaust. bike starts fine and has good low end grunt but on the top it sounds like there is a rev limiter. obviously its running out of fuel and needs re-jetting. all carb jets are stock, and all the settings are stock also.
i live in michigan and will be doing most of my riding in the summer. any info will be greatly appreciated shawn
  • Numskull
Posted March 23, 2006 - 07:38 AM
There is the potential for your throttle to stick wide open with the throttle stop completely removed. You can either use the yz stop or cut the stock one to length following these direction
  • byggd
Posted March 23, 2006 - 09:10 AM
I have the same bike. You can get a lot of jetting info in the jetting D-base sticky thread. Here is what i am running. Hope this helps!
Model (400 - 426 - 450): 02 WR426
Timing (WR-YZ): YZ with 03 exhaust cam
Main jet: 170
Pilot Jet: 42
Fuel screw (turns out): 1 1/2
Needle model/Clip position: JD blue needle postion #3
Airbox lid (on or off): Lid Off
Pipe: White brothers e-series w/six discs and quiet core insert
Altitude where you ride: So Cal 0-4000 ft
Temperature where you ride: 75-110
Degree of satisfaction: Runs awesome quick response/no bog
