Engine Life
28 replies to this topic
  • Nevada Tom
Posted March 22, 2006 - 01:55 PM
I have a 05 WR450, FMF pipe, Quick Shot Accelorator pump, all the free mods, and run 14/52 gears. I ride 2-3 times per week 20-30 miles per ride, I change oil and filter every 2 rides. What kind of life can I expect from the motor and bike at this level? I am toying with the idea of buying a new bike this will help with the decision.
Thanks
  • Matty05
Posted March 22, 2006 - 03:16 PM
If you change the oil that frequently, it will last a very long time.
  • 642MX
Posted March 22, 2006 - 05:31 PM
Thats a difficult question to answer. It sounds like you change your oil often enough, but do you use a clean air filter for every ride? Do you replace the timing chain once a year? Do you keep an eye on the valve clearances? Are you on the rev-limiter constantly?
  • flatnacker
Posted March 22, 2006 - 05:55 PM
You are supposed to change the timing chain once a year?? :thumbsup: :thumbsup:
  • 642MX
Posted March 22, 2006 - 05:58 PM
Yes, a worn timing chain will tear up the gear on the crank. The gear on the crank is part of the crankshaft and cannot be replaced without replacing the crank. Timing chains are cheap and easy to put in, cranks are not.
  • old man dan
Posted March 22, 2006 - 05:59 PM
A little off topic but how long have you been running that gearing, why did you choose it and are you happy with the difference. I've been toying with the idea of going to 14/52 myself so that I can get into 2nd more on single track. I don't think I want to go all the way to 13/50 because I'm a little afraid 1st would be useless then.
  • ncampion
Posted March 22, 2006 - 06:01 PM
I have never changed the timing chain in my 98 WR400. That's 8 years of consistant desert and mountain riding including up and back Baja. I runs in an oil bath and properly tensioned at all times. Don't see why it can't last the life of the engine.
  • flatnacker
Posted March 22, 2006 - 07:16 PM
How can you tell if its worn? Is itthe same as chain and sprockets-if it pulls away from the cam teath? :thumbsup: How much is a cam chain?
  • 642MX
Posted March 22, 2006 - 07:25 PM
I guess you can tell when your tensioner is all the way out and the motor jumps time and then self destructs. I replace mine every year, that way I don't have to worry about it failing. Chains run $20-30 dollars and take about 1 hour to install.
  • flatnacker
Posted March 22, 2006 - 07:40 PM
Lol, hmmmmm well for $20-$30 you might be onto something!!! Never really taken much notice of how far out my chain tensioner was...do you notice much stretch in a years worth of riding? Mines an 03 and never been replaced!!
  • Matty05
Posted March 22, 2006 - 09:22 PM
Cam chains are way more expensive here in Australia, they don't really need to be replaced every year.
  • bluebike1999
Posted March 22, 2006 - 10:37 PM
yes matty, most yamaha part suppliers are asking around $95-115 aud
they are $45 plus freight from here
http://www.jp-parts.com/index.html
  • TimBrp
Posted March 23, 2006 - 04:07 AM
While I agree a properly functioning chain is required...I don't think it's needed every year. You've got to think globally when referring to engine wear. Keep up on your valves, air/oil filters and oil changes and other maintenance along with calculating in how you ride. Are you revving to the moon all the time? The more RPM the bike runs at the more wear and tear you will see. Same principle is used for diesel engines, the cummins especially. Diesel motors are designed to produce most of their power down low in the RPM scale, usually between 500-3000. Therefore the less that piston/ring combo is spinning the less wear on the cylinder and it's counterparts. This is why diesel engines can go 300,000 miles and the gas jobs suffer. Anyhow... a properly maintained, trail ridden WR should get you at least 4+ years of every weekend riding 40-50 miles....maybe more but that's an acccurate assumption, IMO. If you're concerned about it that much, have it looked into by a reputable mechanic/shop. Nothing like a little reassurance before you hit the trail... :thumbsup:
  • 642MX
Posted March 23, 2006 - 07:18 AM
One of my riding buddies has a 03 YZ450. I replaced his chain before last summer, (he rides probably twice a month) and his lower gear was showing some wear.
Do what you want, but these guys that say they don't need replaced need to pop their flywheel off and have a good look at that gear. I bet it has wear, and it came from a chain that is stretched.
  • TimBrp
Posted March 23, 2006 - 07:21 AM
Again, that's a full on race bike. Not a detuned WR trail bike. Like I said, it all depends on how you ride. Stress beats up a motor.
  • 642MX
Posted March 23, 2006 - 07:28 AM
Not really want to argue with you, I'm just here to offer advice. But, maybe you can explain to me how you know how this particular YZ has been treated? And also the differences between a WR motor with all the free mods and a stock YZ motor?
  • Numskull
Posted March 23, 2006 - 08:01 AM
you got that right, as soon as it jumps time, the life of your motor just expired :thumbsup:
  • TimBrp
Posted March 23, 2006 - 09:38 AM
Here we go with the "what if's". The advice is appreciated although not all advice given is accurate. Take both sides for what they're worth. It was an assumption...just as you assume the timing chains should be changed every year. Why buy the YZ to moderately use and trail ride? It's a race bred machine, that is it's intended use. I'm talking stock or uncorked(read:no timing or cam adjustments) WR vs. Stock YZ. To be honest I really hope you're wrong...although you may be on to something... :thumbsup: If my gear shows wear after one year...I'll sell the yammie and go back to my honda XR's. No issues with them. :thumbsup:
  • Nevada Tom
Posted March 23, 2006 - 10:03 AM
I switched to that setup 14/52 6 months ago and really like it. In fact I am toying with going to a 13/50 for the low end grunt on dicy up hill single tracks.
TG
  • Nevada Tom
Posted March 23, 2006 - 10:12 AM
Just finished reading the threads, I ride pretty hard probably average RPM in the 5500 to 7000 range. I really like the bike and it runs really strong I am just wondering if because I ride it hard should I go for a YZ or CRF 450 while this bike is still in really good shape to sell.
TG
