hesitation on accell
23 replies to this topic
  • byggd
Posted March 23, 2006 - 09:05 AM
#21
I agree, but not one person has asked for your jetting specs. I think you should tear into your carb, for a good cleaning at least, and figure out which jets you are running. Post your specs and I'm sure someone can make a much more well informed recommendation.
Being the TPS didn't solve the problem this is the best advise yet. Hook the TPS back up and let us know what jets, needle position, altitude etc.
  • dbailey223
Posted March 23, 2006 - 09:45 AM
#22
Don't hook the grey wire back up, unless you put the stock WR throttle stop in :thumbsup:
  • Matty05
Posted March 23, 2006 - 02:29 PM
#23
Hmmmm, it is never TPS! :thumbsup:
  • OneToGo
Posted March 24, 2006 - 02:42 AM
#24
Yep, do a search and check the retardation in the ignition curve above about half (WR stop) throttle
THEN, you'll convince yourself that the Gray wire goes and the YZ stop stays... :thumbsup:
