Where to get seals and gaskets?
3 replies to this topic
  • MTRSPORTDAN
Posted March 20, 2006 - 07:12 PM
I have to split my cases and was wondering if anyone sells a complete kit with seals and gaskets. I think maybe a bearing kit also since I will be in there. Any help would be great. Thanks, Dan
  • timcook
Posted March 20, 2006 - 07:38 PM
I usewww.bikebandit.com for all OEM parts. It allows you to look up parts just as the dealerships do. As for a kit, you will have to carefully pick out each item separately. I have used them to order large assortments of parts with 100% success.
Hope this helps,
Tim
  • MTRSPORTDAN
Posted March 21, 2006 - 07:15 AM
That's what I am afraid of. I was hopeing somebody sells a kit. Thanks for the reply, Dan
  • bluebike1999
Posted March 21, 2006 - 07:25 PM
MTRSPORTDAN this may sound strange, but are you sure there is a gasket between the two cases?
if you go here
http://www.yamaha-mo...parts/home.aspx
you can enter what sort of bike you have and determine the part numbers, but there does not appear to be a case gasket and i'm thinking it may be just gasket cemented.
as for the gaskets
get a quote from these guys and see how you go.
http://www.jp-parts.com/index.html
good luck
