XL600R fork options ?
5 replies to this topic
  • Nummie
Posted March 20, 2006 - 05:53 PM
I just got a rather new set of XR650L forks and am wondering
if they will fit on my 1984XL600R ?
My guess is that they will, but will there be any issues with the
wheel and brake spacing ?
Thanks for any help or advice.
  • pcmartin
Posted March 21, 2006 - 09:21 AM
This has been tried before and hasn't worked yet. The tubes are bigger so you can't use just the forks. And the steering stem is different so you can't just use the 650 triple clap. So far as I know no one has tried pressing out the two steering stems and machining the 650 triple clamp to accept the 600 stem. This would require welding the inside of the triple clamp then boring it to fit the 600 stem. Then you would want the 650 wheel and brake set up to avoid the problems with spacing. I feel this is too much work for little gain. I think I'd be looking for a fork brace if I thought I needed a stiffer fork set up. I have a 85 XL600R that I've ridden every thing from the woods up near our rancho in northern AZ, to the deserts of Baja and I've found the forks to be the least of my problems.
  • Nummie
Posted March 21, 2006 - 01:18 PM
Thanks for the advice.
I may just try to get a XR650L frame as well.
  • Nummie
Posted April 24, 2006 - 11:04 PM
Well its a good thing I didn't believe your advice.
Turns out the XR650L forks fit perfectly on my XL600R.
The axle on the XR650L forks is larger though, so now I'm looking
for a front wheel to go with my new forks.
  • don87xr600
Posted April 25, 2006 - 07:26 AM
check if the 650 bearings will fit in your 600 wheel.
  • terdog
Posted April 25, 2006 - 07:35 AM
I have a 93 XR 628. It has the best set up EVER for a XR... CR 500 forks! :thumbsup:
  • Hot  28 replies
FCR40 Tuning Woes- XR600R by aTuWitty
  • Hot  37 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
