Does anyone know the size....
7 replies to this topic
  • odonnks
Posted March 20, 2006 - 04:48 PM
Does anyone know the size of the nut that holds the front drive sprocket on?
I'm planning to replace the stock 14 T and know I don't have a metric socket that large. :thumbsup:
Thanks
  • holyroller1
Posted March 20, 2006 - 04:57 PM
My 06 is 27mm
  • odonnks
Posted March 20, 2006 - 05:45 PM
Thank you !
  • odonnks
Posted March 21, 2006 - 06:36 AM
Does removal of the sprocket require a puller or will it come off fairly easy once the nut is removed?
  • hankdog
Posted March 21, 2006 - 07:42 AM
No puller required, it's a standard splined sprocket. Nut is torqued to 54 ft lb. Nut is 27mm, same size as rear axle.
  • odonnks
Posted March 21, 2006 - 08:21 AM
Thanks !
  • Kepy
Posted March 21, 2006 - 12:48 PM
Thanks
The nut is very tight (about 30Nm), so you'll need a fellow sitting on your bike and pulling both brakes otherwise the rear wheel will just slide over the floor :thumbsup:
  • byggd
Posted March 21, 2006 - 02:24 PM
Naaaa just whip out your trusty CP734 air gun :thumbsup:
