450 cam starting problem
6 replies to this topic
  • blazen
Posted March 20, 2006 - 03:46 PM
I just finished the 450 cam mod along with JD jet and needle. It took a while to get started but once it did it ran great. After letting it sit I was no longer able to start. It would backfire on most kicks. Turned the fuel screw out and still the same. Can timing be off even if it ran well? I have an E-line ignition so it is not as clear to line up the timing. Please help I want to ride. thanks-alex
  • 642MX
Posted March 20, 2006 - 04:28 PM
The timing can be a tooth off and still run. (Don't ask how I know that). I would double check your timing first. The exhaust valves will need reshimmed with the 450 cam. You did check your valve clearances after you installed the cam...right?
  • blazen
Posted March 20, 2006 - 04:29 PM
I just got it started by giving it some gas. Usually I never twist the throttle to start. And it is popping on decel now. My main jet is 170 and pilot is a 42. :thumbsup:
  • blazen
Posted March 20, 2006 - 04:33 PM
Yes i did check the clearences. i reshimmed with 190, a little bigger. i will check timming tomorrow. The e-line ignition has no reference for top dead center so i may put the stock flywheel back on to make sure it is timed correctly.-alex
Posted March 20, 2006 - 04:37 PM
If you'd rather, you can simply use a screwdriver in the spark plug hole to gauge the location of TDC.
  • 642MX
Posted March 20, 2006 - 04:49 PM
Thats how I find TDC. Its easier than getting a flashlight and looking in the mag cover. :thumbsup:
  • blazen
Posted March 20, 2006 - 04:52 PM
I used a screwdriver the first time to find TDC but read it may not stay there.
  • 0 replies
  • On January 15, 2017
  • Hot  28 replies
  • Hot  113 replies
  • Hot  50 replies
