Cam chain replacement on 04 450f
44 replies to this topic
  • Schpenxel
Posted June 08, 2011 - 10:17 AM
#41
Gotcha, makes sense. My tensioner fell apart (or I broke it by not removing the cap bolt first, not sure which) so I haven't been able to see how the yz426 ones actually work. The whole thing literally fell apart when I pulled it out. Timing was still dead on when I pulled it apart though.. so it hadn't failed previously.
Ordered a new one obviously but hasn't came in yet.
  • moosekak
Posted October 04, 2011 - 10:00 AM
#42
Just in the process of installing new top end and timing chain in my 06 and am having troubles installing the chain back onto the cams. Any secrets? To install my exhaust cam i have to push my chain guide back to get it in place. With the exhaust cam in and the chain on, the guide is putting pressure on it pretty good, is this normal? looking down with my stator cover off it is sitting in the housing what looks to me being the right way. Any thoughts would surely be appreciated
Posted October 04, 2011 - 10:17 AM
#43
The exhaust cam should clear the chain guide with cam and chain in place. A common mistake when assembling the head onto the cylinder is to push the guide out of position to the rear. There are two pegs on the side of the front guide that locate in corresponding notches in the cylinder, and it is easy to knock the guide out of place while dropping the head, especially while doing so with the engine in the frame.
I'm afraid you'll need to pull the head back off to correct this.
  • moosekak
Posted October 04, 2011 - 11:14 AM
#44
Awwww shucks! I had a feeling it shouldn't be like that, so i dissasemled it this morning and must've knocked it out of place again. Back to the garage for the third time is the charm...... hopefully:banghead:
  • mover
Posted February 07, 2015 - 11:10 PM
#45
Gray, this is an excellent write up. I know I'm a little late to this topic but I'm presently in the process of replacing the timing chain/valve adjustment on my 08 yz450  I've read
that some are having an issue with correct alignment of the timing marks. I found that by marking the chain and sprockets in three spots with a paint pen (one at the bottom of the
crank 6:00 and one just above the timing marks on each cam 9:00 and 3:00. After removing the chain I transferred these marks to the new chain. I found it easier to get all the
gears properly timed.  I'm astounded at all the great information on thumpertalk. Thanks for the help.
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • Hot  50 replies
  • On January 15, 2017
  • Hot  28 replies
