OEM decompression plug
8 replies to this topic
  • Raven1911
Posted March 19, 2006 - 09:17 AM
How in the hell do you put this thing in?? I have the OEM but am thinking of getting the TT plug, but want to try the OEM one first since I have it. Any suggestions? Also, does anyone else make a good decompression plug? I might try and find one at my local shop but not sure what brand to ask for? Thanks
  • BergArabia
Posted March 19, 2006 - 09:33 AM
I bought the TT one and have had it sitting in my bag for a couple of months so I would like to have some advice on how to insert it also.. perhaps it is the same technique as for the oem one?
  • Super G275
Posted March 19, 2006 - 10:07 AM
Follow this forum http://www.thumperta...ad.php?t=352633. Grayracer513 is a great guy with lots of MX knowledge. He's posted pics!
  • Raven1911
Posted March 19, 2006 - 12:15 PM
Thanks, but does the concave side face into the cylinder or away from it??
Posted March 19, 2006 - 05:25 PM
On the OEM plug, the concave faces the interior of the engine. If you've lost one, always check you breather tube for being pinched or blocked off.
If you're clever, you can fabricate a simple retainer that will bolt onto the tab that once held the decomp cable anchor to the head and hold the plug in place.
You can also use an 18mm expansion plug (aka "freeze plug"). That would push in concave face outward, of course.
  • cowboyona426
Posted March 19, 2006 - 05:46 PM
Just get the TT plug or similar, don't waste your time with the rubber one.
  • Raven1911
Posted March 19, 2006 - 09:21 PM
Do I have to have a plug in there. Why can't I leave the decomp assembly in there and just unhook the cable??
  • cowboyona426
Posted March 19, 2006 - 09:39 PM
You could do that, but the plug is much cleaner looking, and there is no chance of it interfering with anything. Just get the plug, you won't be sorry!
Posted March 19, 2006 - 10:32 PM
If you do, be sure the return spring stays with it to keep it from contacting the lifter. You can also cut off the half round extension on the inboard end, cut the lever off, and use the stub of the shaft as a cheap version of the TT plug. That will eliminate the need to move it in order to reshim that lifter.
Motocross
  • Hot  491 replies
  • 9 replies
  • 5 replies
