Could it be timing chain slap or rocks in the crankcase ???
13 replies to this topic
  • odonnks
Posted March 18, 2006 - 03:19 PM
I remember seeing a post somewhere about this.
On my 06 WR450F 80 or so miles. When I'm lugging the engine, especially on a tight incline or putting along in too high a gear, if i give it a little throtle it sounds like thre are rocks in the crankcase.
Its not enough load on the engine to be detonation. Once the engine spools up it quits.
Is this timing chain slap?
If so, is it anything to worry about?
Thanks
  • dl19
Posted March 18, 2006 - 04:08 PM
I heard the same thing on my 05. It is actually drive chain slap on mine. Ride it with out a helmet, and you can easily hear and notice where it is coming from.
  • odonnks
Posted March 18, 2006 - 04:11 PM
I'll try tomorrow w/o helmet
Thanks
  • andy666
Posted March 18, 2006 - 07:53 PM
My 06 sounds the same i just put 50 mils on it today with a total milage now of 128 miles on it without a problem Theses engines are noisy.The noise seems even louder with the IMS tank on it .
  • Kepy
Posted March 19, 2006 - 06:19 AM
Thanks
It's a drive chain matter in my opinion. I put a silicone under my chain slide to get it more muffled...it worked great to me. Use a silicone from the cartouche and the appropriate cartouche gun :thumbsup:
  • odonnks
Posted March 19, 2006 - 05:14 PM
I think Kepy was correct.
I rode today and paid close attention to the noise when lugging it along.
Sounds like its coming from the drive chain.
Thanks
  • Dodjy
Posted March 19, 2006 - 05:32 PM
It'll be the drive chain. The manual settings are too loose. I had the ame problem and started a thread a while back. Most advised to either tighten the chain or the silicon trick. I use 45mm from the middle of the chain to the top of the bolt. This fixed the problem on my 05 and I've never had a problem since.
  • odonnks
Posted March 19, 2006 - 06:37 PM
I'm not sure what the silicone trick is.
Can someone explane?
  • Bamster
Posted March 20, 2006 - 05:50 AM
odonnks
Put a bead of silicone under the top section of this
Between it and the swing arm.
I would be careful not to tighten the chain too much as this could put too much stress on the the counter shaft when the suspension compresses
  • odonnks
Posted March 20, 2006 - 08:52 AM
Thanks, I'll give it a try !
  • Bosco83
Posted March 20, 2006 - 12:27 PM
I also notice that the plastic radiator guards make a lot of rattle and it's really annoying. But man I love this bike this is my 4th ride and I'm so glad I chose te 450 over the 250.
Brian
  • MountainMax
Posted May 13, 2006 - 04:02 PM
Can someone post a larger pic on where to put the silicone to quiet this noise?
  • odonnks
Posted May 13, 2006 - 06:24 PM
Look at the chain slider on top of the swingarm. Its held to the swingarm with screws.
Remove the screws and put the silicone under the area beneath the slider.
The slider is not tight against the swing arm and when the chain hits it, it transfers the noise to the swing arm.
You should use a oil resistant silicone.
  • MountainMax
Posted May 13, 2006 - 06:51 PM
ok, i just went out to my bike and checked it out, i got ta now. Will try mine soon.
