clutch boss?
6 replies to this topic
  • crfdaddy
Posted March 17, 2006 - 05:45 PM
i,m still got the clutch apart just bought oem friction plates,steel clutch plates and springs all oem through the tt store thanks. while having it apart i noticed some scoring iside the clutch boss where the first friction plate would make contact, should i replace? also is the clutch boss suppose to move freely about 1 1/2" either direction ? the second i rotate the basket it will move the rear tire either way, so i'm assuming thats working ok. thanks again for the inputs
  • ncmountainman
Posted March 18, 2006 - 06:50 AM
had the same problem with mine either something got in there and scored it or it was a poor machining job from the get go. its only $55 OEM. considering the aftermarket ones are $200+ its a pretty good deal :thumbsup:
  • crfdaddy
Posted March 18, 2006 - 11:03 AM
thanks nc for getting back with me. i been looking on ebay to see whats available i'm leaning towards a hinson unit but that $55.00 for oem may lean me more towards oem. thanks again john
Posted March 18, 2006 - 01:35 PM
The GYT-R Clutch Boss is a Hinson part for less than a Hinson retail price. Keep it in mind if you can't find a deal on a Hinson.
  • crfdaddy
Posted March 18, 2006 - 05:48 PM
thanks gray racer also there are some yz tripple clamps on ebay right now pro circuit upper and lower nice looking set but i don't think there the same offset that you run on your yz. if you don't mind what brand tripple clamps you running to get the 22 1/2 offset? thanks john
Posted March 19, 2006 - 12:06 AM
The clamps are from Applied
  • crfdaddy
Posted March 19, 2006 - 12:08 PM
thanks grayracer after i get finished with replacing the clutch, i will be looking for some offset clamps to help the bike turn better
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  113 replies
  • Hot  47 replies
  • Hot  30 replies
