04 Wr450 Questions
1 reply to this topic
  • RIDER307G
Posted March 16, 2006 - 08:20 AM
Just bought it and it has all free mods, but I didn't do them. The airbox right now has a snorkel type of inlet on the top with a piece that runs across the top to divide the one large opening into two. Do I remove this? It also has the holes cut in the sides.
Also, the clutch lever and perch has a wire and switch in it. What does it do and what happens if I replace the perch with an aftermarket one that does not accomodate this?
Thanks for the help.
P.S. what is the distance that can be done on the stock tank?
  • simon@vic
Posted March 16, 2006 - 08:26 AM
MAKE SURE!!!!!!!
The airbox right now has a snorkel type of inlet on the top with a piece that runs across the top to divide the one large opening into two. Do I remove this??
take it out!!!
you dont need that!!! it is a clutch safety switch and will brake on you eventually any way. cut the wires where they come out of the plug under your headlight. strip them , twist them together, and put shrink wrap over it.
110-150km on all 10L.
rememberer to have fun and change your oil ever 200-500km!!!!
