Carb just dumping gas out??? Help
21 replies to this topic
  • steve lemley
Posted May 06, 2006 - 07:32 PM
#21
Thanks, I cant seem to get it to stop, sometimes its okay and others it leaks bad??? I am just going to have to replace the seal, I thought it would clear its self but I guess not. Ive cleaned it twice and no luck. Bummer at 40.00 just for a seal. Oh well, I guess things could be worse. At least its not my valve seals right!!! :crazy:
  • SilverTalon
Posted May 06, 2006 - 10:34 PM
#22
Have the same problem after running 10% Ethanol fuel... Obviously sped up the process of ruining the o'ring... I will pull the bowl off for the third time and see what the damage is. I'll probably replace with an o'ring that will not deteriorate with the ethanol fuel.
Cheers for the help!
