05 Tail Light
6 replies to this topic
  • taksx
Posted March 14, 2006 - 07:28 PM
Anybody have any issues with their tail light?
mine stopped working, bulb is still in good shape, head light works fine.
Any thoughts :thumbsup:
Eddie
  • grappler
Posted March 14, 2006 - 07:49 PM
Do you have a multimeter available? You could just verify if you are getting voltage to the light by checking at the connector under the seat. That is, if it's the same setup as the '06.
  • taksx
Posted March 14, 2006 - 08:43 PM
:thumbsup: humm good tip ima try that, thanks.
  • camaro345
Posted March 14, 2006 - 11:15 PM
Did you check the plug in connector thats right under the seat??
  • tmckeown
Posted March 15, 2006 - 12:24 AM
Hi,
I was fighting with mine, those connection really :thumbsup:
I finally changed to LED rearlight and hook it to battery.
Timo Mc
  • taksx
Posted March 15, 2006 - 08:40 AM
Yup its pluged in.
Is it always on or do you have it set up when you brake it turns on?
  • tmckeown
Posted March 15, 2006 - 11:43 AM
Hi,
I have a setup that it is on only when your main is on , brakelight has a pressure switch and it gets 12v only when main is on.
Here you can find more about it:
http://www.thumperta...ad.php?t=324690
Timo Mc
