Cam Chain Tensioner Install
6 replies to this topic
  • mulisha00
Posted March 14, 2006 - 07:48 AM
I am almost done with the 03 cam mod in my 426 and with help of another TT member I was told about the cam chain tensioner. I completly removed mine from the engine when I did the mod.
What do I need to do to get it back together right. I did searches and found little bits but nothing solid.
Is it supposed to move in and out if you press on it for supposed to be tight?????????? Please help quick as I'm off to the dealership right now to get my shims.
Thanks. :thumbsup:
  • cowboyona426
Posted March 14, 2006 - 07:57 AM
mulisha, push on the tensioner and wind the screw... as you wind the screw it will retract, and once the screw stops turning it shoud stay retracted. Bolt the tensioner in, give the screw a little jiggle, and it will release and tension the chain. Hope this helps.
  • RD73
Posted March 14, 2006 - 08:06 AM
You'll need a small thin screwdriver to gain access to the screw.
Posted March 14, 2006 - 08:30 AM
You're not using a manual? Here:
http://motoman393.th...426_manual.html
Remove the bolt with the 10mm head from the end of the tensioner. put a small screwdriver in the hole and find the slot in the end of the spring holder. Turn the screwdriver to wind the spring up. As you do, the plunger will be drawn in. When it gets clear to the end, it should catch and hold in the completely retracted position. Then, bolt the assembly to the cylinder, stick the screwdriver back in the hole and give it a little turn the opposite direction of that which wound it up. It will spring down against the chain and take up any slack it finds. It's totally self-adjusting, so that's the whole procedure.
  • mulisha00
Posted March 14, 2006 - 08:41 AM
Gray THANKS but I already have the manual downloaded on my computer at school. I'm in for spring break using a friends computer and cannot download anything to it.
Thanks to all for the quick info. I'm off to get some shims. :thumbsup: :thumbsup: :bonk: :confused:
  • MotoGoalie
Posted March 14, 2006 - 10:54 AM
I think kelstr was advocating using a MANUAL chain adjuster to avoid any problems (ive never heard of any problems) What do you guys think of that idea?
Posted March 14, 2006 - 11:20 AM
I know he'll disagree, and he's not the only one who has suggested it, but I haven't seen a verifiable case where the chain tensioner failed. The way they're made, it would be very difficult to cause one to slip. If anyone has a defective one that has let a chain back off to send me, I'd love to have a look at it.
The main shortcoming of a manual cam chain tensioner is that it's another thing that requires attention (often). That, and the difference between the right tension and either too much or too little is very small, and there are potentially serious consequences for making either mistake, too. Manual adjusters may have a place in a very highly modified all out race engine, but I don't see that they offer most of us an advantage, or that there's a problem that need to be fixed.
  • Hot  36 replies
  • Hot  38 replies
  • On January 15, 2017
  • Hot  30 replies
  • Hot  47 replies
