Blown top end???
7 replies to this topic
  • Wascher808
Posted March 13, 2006 - 11:13 PM
I own a 00 yz426. i love the bike, but last fall i blew it up. I was cranking around in a field, and all of the sudden it acted like it had no power, So i left off the gas, and it wanted to stall, i thought it was running out of gas but it didnt. It will start back up even now, but will not stay running and there is alot of scraping. I have not torn in to it yet, i just wanted to see if anyone has had this problem, and what it sounds like, i think its a ring i just wanted to see if it could be more then that. It doesnt have to much compression. I am also thinkin of putting a high compression piston and rings in, i wanted to hear what everyone had so say about that. Please help me thanks!!
  • Punisher660
Posted March 14, 2006 - 08:07 AM
If you hear scratching - your probably going to need a bore and cylinder replating :thumbsup:
I wouldn't start it again until after you tear into it.
  • Wascher808
Posted March 15, 2006 - 04:54 PM
yea i knew better the first time, but you get a few beers in you, and the story changes.. Any word about high compression.
  • 642MX
Posted March 15, 2006 - 04:57 PM
High compression pistons are awesome. I've had one for a couple years and they really improve the off idle snap and midrange pull. I would recommend the Wiseco 13.5:1 piston. :thumbsup:
  • 450_rider
Posted March 15, 2006 - 06:41 PM
642MX, what type of fuel are you using for your 13.5:1?
  • 642MX
Posted March 15, 2006 - 06:50 PM
Citgo 110 octane leaded. It will run with pump gas, but it pings a bit.
  • 450_rider
Posted March 15, 2006 - 07:41 PM
I thought you couldn't run leaded gas in these bikes? Would premium with octane booster be enough or go with U4. Its almost time for a new top end and i was thinking Wiseco.
  • 642MX
Posted March 16, 2006 - 07:14 PM
You can run leaded fuels. Lead helps lubricate the valves, and leaded fuels are easier to dial the jetting in with. I've been using that fuel for about 3 years now. U4 is too expensive for me, and I wouldn't recommend the bottles of octane booster, they can cause some problems when used incorrectly. There is a company called Renegade Fuels, they make PRO102 race fuel that is unleaded. You may want to check that out if you don't like leaded fuels.
