Check those spokes!
15 replies to this topic
  • NYMXer
Posted March 13, 2006 - 03:19 PM
I just checked mine and all were loose. This is after a bout 3 hours on the bike. Tighten them and hope they're seated in for good. :thumbsup:
  • 642MX
Posted March 13, 2006 - 03:50 PM
You should really check them before every ride. I've had a couple work loose on wheel sets that where a couple years old.
  • Drfletcherdc
Posted March 13, 2006 - 05:04 PM
Just about all of them were loose on my 06 450 also. Lucky I remember to check them, it's not something that I normally think about.
  • Matt96xr6
Posted March 13, 2006 - 06:42 PM
You will have to check them for the first 3 rides on the bike. Especially the fronts on the YZs.
After that, they usually stay seated for a while.
  • cowboyona426
Posted March 13, 2006 - 09:31 PM
What is the tightening pattern- every 3rd spoke isn't it?
  • NYMXer
Posted March 14, 2006 - 05:45 AM
That's what I did. I must have lost count because on the front wheel one time I came back to where I started after 1 rotation.
BTW, the factory spoke wrench worked fine. :thumbsup:
  • CRFThumper
Posted March 14, 2006 - 05:56 AM
It's really every 4th spoke.Or do one count three do the next one.That way you will be doing a right and then a left then a right and so on. :ride:on a side note:I'm gold!!!!wahoo
  • Jaycycle
Posted March 15, 2006 - 03:47 PM
I'm confused, what do you mean by tightening pattern? On my usual check up I just take a wrench to each spoke and tighten them up. :thumbsup: Excuse my noobieness I'm a youngling.
  • Jaycycle
Posted March 15, 2006 - 03:51 PM
Well, now that I reread that I assume that you only tighten every third spoke? If so why would that be, why not just tighten all?
  • CRFThumper
Posted March 15, 2006 - 04:11 PM
If you do it like above you are tighten first the right side then the left side!
Helps to keep everything centered.
  • beezer
Posted March 15, 2006 - 04:37 PM
There isn't any tightening pattern.
Do a quarter turn on each and keep going around the wheel until they all tight.
Most of you can't count anyway.
  • Nalgene
Posted March 15, 2006 - 04:53 PM
The Correct method preached by all mechanics is start at a spoke near the rim lock and go (either direction of that spoke) every 3rd spoke to tighten. After 3 rotations of the tire you should ( if done correctly ) end up at the rim lock spoke you started at. Also a torque wrench is a great tool to take the guessing out of it. I just picked up a excel torque wrench for like $100, and it came with 5 heads and a spline drive head. $100 investment instead of having to buy new wheels later down the line. I think 45lb is the general agreement on the torque, but I could be quoting the article I read wrong.
  • beezer
Posted March 15, 2006 - 06:00 PM
A torque wrench might work on a new wheel. Once you get the bike dirty it won't
Don't make a simple job complex. Crack a beer, sit on a milk crate and just tighten the things.
  • Nalgene
Posted March 16, 2006 - 05:47 AM
Wash bike after every ride :thumbsup:
  • ditchound
Posted March 16, 2006 - 01:48 PM
Do you mean 45 lb/ft or 45 lb/inch? I usually do 4 or 5 lb/ft which is 48-60 lb/inch.
  • Nalgene
Posted March 17, 2006 - 03:28 AM
maybe its inches.. to early in the morning to look.
