2006 YZ450 Flaw?
9 replies to this topic
  • dugbud
Posted March 12, 2006 - 07:46 PM
Today we were at Clear Creek. It was snowing off and on, a lot of standing water and our bikes got really wet. My partner and I both have 06 yz450's and we both had problems with our bikes today? When rolling off the throttle the bike would pop and the engine would die? If you kept reving it it would stay lit but, popping and bogging the entire time. Now I;ve owned about a dozen motorcycles in my career and water has never been a factor with something like this unless of course you drop it it the river. I have re jetted to a 48 pilot jet and have the boyeseen acc pump cover. Is there a flaw in the bike? Has anyone else had this problem?
  • 642MX
Posted March 12, 2006 - 08:14 PM
Sounds like you need a fuel screw adjustment.
  • dugbud
Posted March 12, 2006 - 08:18 PM
We'll I have an STR fuel screw and tried adjusting it but with no success? If it was the fuel screw adjustment why would it run above 1/3 throttle flawlessly?
  • jbrooks26
Posted March 12, 2006 - 08:22 PM
Because the fuel screw has very little effect above 1/4 throttle. Once you get above 1/4, you are into the main and needle. Hope this helps.
Josh
  • 642MX
Posted March 12, 2006 - 08:23 PM
Because at 1/3 (and up) throttle your carb uses the needle and main jet. At low speeds your pilot and fuel screw are in control.
  • jbrooks26
Posted March 12, 2006 - 08:25 PM
HEY!!! That is what I said!! Get your own answer. LOL
Aren't we a bunch of brainiacs!!
Josh
  • dugbud
Posted March 12, 2006 - 08:32 PM
okay so do i adjust it out or in?
  • kid on a 426
Posted March 12, 2006 - 08:46 PM
well it sounds to me like its too lean so richen her up a bit and you'll be fine
  • jbrooks26
Posted March 12, 2006 - 08:50 PM
Out is richer, in is leaner. Adjust it until you don't have the popping any more. 1/8 to 1/4 turn at a time and then do a test run. If you end up with the fuel screw out more than 2 turns go to a bigger pilot and start over again with the screw. In more than 1 or 1/2 turns than time for a smaller pilot. Hope this helps.
Josh
  • Matt96xr6
Posted March 12, 2006 - 08:55 PM
probably got a lot of water in the airbox and filter. Thus water does not burn, so you need to keep the rpms up to keep it running.
Bet you dry things out, install a new clean filter and the bike runs like a champ again.
