greasy pig
10 replies to this topic
  • Guest_Guest_*
Posted January 05, 2001 - 07:57 AM
I will be taking the WR apart to grease all the fittings before it first ride. At this point I am planning on using LPS Thermaplex Aqua grease. I have used this in many wet industrial aplications and it works great. I haven't used it on any needle bearings or small aplications like such. Does it matter what grease to use?
  • Scott_F
Posted January 05, 2001 - 08:02 AM
Waterproof grease would suffice, but you might consider buying a small tub of moly grease for a few bucks.
  • Brian_in_Long_Beach
Posted January 05, 2001 - 08:42 AM
I used the Honda moly paste (per Clark's recommendation) for the linkage and other spots that call for moly as shown in the manual.
  • Scott_F
Posted January 05, 2001 - 08:50 AM
I found that just using moly paste can dry out too easily, and moly grease is the best. YMMV.
  • Guest_Guest_*
Posted January 05, 2001 - 09:53 AM
this may be a dumb question, but what does moly stand for? Who makes it
  • Guest_Spudman_*
Posted January 05, 2001 - 01:45 PM
Hmmmm, let me see it I can spell it right. Molybdenum???
  • Michael
Posted January 05, 2001 - 03:07 PM
More than just molybdenum - which is a metallic elememnt which is alloyed with iron to make cutting tools and other stuff (like motorcyle frames) - it stands for Molybdenum Sulfide (or molybdenite). This is a graphite like compound that increases load capacity of grease.
  • Scott_F
Posted January 05, 2001 - 08:58 PM
Correctomundo. I always thought it was molybdenum disulfide.
  • Michael
Posted January 05, 2001 - 09:28 PM
I stand brain can't handle the strain anymore. I wrote disulfide and then switched to sulfide several times. For the life of me I couldn't remember. But a quick check of old books (long time on the shelf) and there is the answer - Molybdenum Disulfide (MoS2).
Goes to prove that there are no dumb questions - just dumb answers!
  • Guest_Guest_*
Posted January 06, 2001 - 04:17 PM
Mobil 28 synthetic aviation grease!
  • Guest_Guest_*
Posted January 08, 2001 - 03:12 AM
Thanks for the input.
I will give molybendumover a try.
Is it waterproof?
Seriously, thanks guy's.
