Over Heating Wr450 2005
14 replies to this topic
  • Bladerunner426
Posted March 12, 2006 - 03:04 PM
My WR over heats frequently. I go through an 80 mile desert race my overflow reservoir will be at the correct level. After the race the reservoir will be empty and the radiator will be 1/4 low. I understand if the terrain is technical and the bike isn't moving fast enough to cool it but it over heats too easily. My other friends with WR's don't have the problem i do. I have only done the grey wire, baffle out, and air box mods. Everything else is stock. Any help appreciated! Can this have anything to do with jetting?
  • clark4131
Posted March 12, 2006 - 03:08 PM
You're probably running too lean and the bikes running too hot. What's your elevation and what jets are you running?...SC
  • Yamaster
Posted March 12, 2006 - 03:11 PM
Thats what I think is the problem also.
  • dl19
Posted March 12, 2006 - 03:24 PM
Too Lean!!!! By opening up the bike even the amount you did you will lean it out. Re-Jet and it will be fine.
  • timcook
Posted March 12, 2006 - 03:36 PM
I have rode my WR in a wide variety of Arizona [COLOR=DarkRed]heat[/COLOR]. This thing has never overheated. The only time I've come close was at Glamis after I realized I still had my 160 main in from riding at 6500 feet weeks earlier. I also agree that you may be too lean. These bikes run even if jetting is way off.
Good luck
  • Dodjy
Posted March 12, 2006 - 04:02 PM
I agree it is lean, I used to have the same problem until I got the jetting right then haven't overheated since. Richen it up and it probably won't overheat again. Look at the jetting database and start from there.
  • ARin
Posted March 12, 2006 - 04:31 PM
lean cuisine
richen it up and it will run cooler.
  • snakesausage
Posted March 12, 2006 - 05:43 PM
I had the same problem on my 05' until I rejetted. The hot Texas summer and slow riding in the woods would overheat once or twice a ride until the change.
Model (400 - 426 - 450): 2005 450
Timing (WR-YZ): WR
Main jet: 168
Pilot Jet: 48
Fuel screw (turns out): ZipTy - 2 turns
Needle model/Clip position: Stock
Airbox lid (on or off): Snorkel out, punch-outs removed
Pipe: Stock, baffle removed
Altitude where you ride: 100 to 1500 FT
Temperature where you ride: 55F - 75F
  • DCaddy
Posted March 12, 2006 - 08:06 PM
I would like to also suggest that you get the PMB exhaust insert also to help it breathe and let some heat out. The pea shooter exhaust just doesn't get it. Do the throttle stop also and let-er rip.
BTW Jetting is easy....Don't let it scare you, JD comes with all the instructions you'll need, Here is some more just in case.
http://www.thumperta...ad.php?t=309069
I did not find it necessary to remove the entire float bowl to replace the main jet... just the big plug screw in the bottom of the carb.
  • YamahaWR450FMike
Posted March 12, 2006 - 08:56 PM
my 2004 WR450 runs so cool after about 15 minutes after riding it, I have to use the choke to get it started again cause of it cooling down so quickly
  • gregwr450f
Posted March 14, 2006 - 02:33 AM
Since you losing fluid, you must have a leak, replace your radiator cap.
  • newzealandwr450
Posted March 15, 2006 - 11:44 PM
Thanks for all of the help guys i will get that jd jet kit and take care of this problem.
  • gregwr450f
Posted March 16, 2006 - 12:07 AM
Then fix the problem and replace your rad cap :thumbsup:
  • 05BlackTaco
Posted April 08, 2006 - 07:31 PM
Question guys. I have an 06 wr450 and I only h ave about 116 miles on the odometer. Last time I went to go ride I hit my friend with my left radiator. I kept riding and everything felt fine but tonight, after I rode my bike and was parking it in my gaarage, I noticed a little bit of smoke rising from the radiator area. When backing up the bike to reposition it, a little bit of smoke rises into the headlight area and thats how I know that it is kind of smoking. Is it just because the radiator is hot or is my radiator damaged? thanks.
  • hall1012
Posted April 08, 2006 - 08:56 PM
The same thing happened to my 04 when it was new. The problem was the rubber boot connecting the carb to the motor, and also the one connecting it to the airbox. The factory didn't tighten the clamps enough, so the engine was sucking in outside air, as well as from the airbox. I had to remove the metal cylinders on the bolts to make it even more tight, but ever since then it has been perfect. Try that out...
