PMB insert or FMF q2
1 reply to this topic
  • XRYoda
Posted March 11, 2006 - 12:01 AM
I jsut got a new 06 wr450f. I would like to know if there is much diference in power between the PMB insert or the FMFq2 muffler. Anyone use both? I will be buying one or the other soon, and dont want to waste my money if there is not much difference.
Thanks!!
  • OneToGo
Posted March 11, 2006 - 01:00 AM
Hi,
There has been quite a bit of debate about exhausts THIS and exhausts THAT on this and probably other Forums as well - understandably as it seems to be one of the first items that incurs, along with suspension, the Big $ $pending!- you might wish to run a search and scan past comments on this matter:
Thanks!!
As a rough guide for WRs see the folllowing from the FMF website (you did say you were looking at a Q2!): Have a look at the Dyno graphs for 03WRs...you could dispute thay are not applicable for later models - but its the only quoted figs. I can find.
http://www.fmfracing...oroom.asp#yam18
FMF Racing
Some other TT members may be able to provide more accurate data. You can see - not much difference, at least for the 03 Model! (it compares Q2 with Typical insert)
As for noise, I think the PMB and Q2 are probably similar - close anyway. Both should be under 96Db if that is and issue.
As for price - well you know this. TT will give you a good deal on whatever you buy - they have the 110% price garantee - ALWAYS cheaper than other internet suppliers! I have used it - it works.
IMHO? get the PMB, setup your bike (everything else, search www.thumperfaq.com) , then if you get tired and want a new pipe - go for it!
Enjoy TT, and the bike, good choice, my .02
Colin
:thumbsup:
