Tips or Suggestion before installing my Boyesen Quickshot
10 replies to this topic
  • Drfletcherdc
Posted March 09, 2006 - 05:02 PM
Just got my quickshot today for my 06 450 and want to know if anyone found short cuts or just an easier way of doing it. Also if there is anything to watch out for... not a mechanic but play one in my garage.
  • YamahaThumper
Posted March 09, 2006 - 08:13 PM
Im pretty sure its straight forward...drain the gas out of the carb...loosen the thingys on the motor intake and air boot and twist the carb so the bottom is facing you.
  • gdbarr1976
Posted March 09, 2006 - 08:19 PM
I put one on my 06. Had to pull the shock to get to it. I am sure someone will say there is a easier way but I can't figure it. It does work though!
  • SureBlue
Posted March 09, 2006 - 08:26 PM
and remove the hotstart from carb, also it helps to disconnect the TPS cable connction under the tank as the cable is tight. When you have the hotstart removed, put some grease in it to prevent it from getting corroded. Be careful with the plastic threading.
  • DirtCheapJohn
Posted March 09, 2006 - 08:31 PM
A #40 or #42 leak jet may help out too...
I know it did on earlier models, don't know about the '06.
  • ncmountainman
Posted March 10, 2006 - 06:01 AM
be careful with the little screws,i think yamaha used plastic to make them. i replaced mine with allen heads :thumbsup:
  • devo1
Posted March 10, 2006 - 07:13 AM
There is one o-ring that is flat on one side and round on the other side. Make sure the flat side faces the quickshot.
  • DPW
Posted March 10, 2006 - 07:58 AM
'06 now has allen heads on the bowl....just a FYI..
:thumbsup:
  • HFD267
Posted March 10, 2006 - 08:05 AM
I did it without removing the rear shock but if I had to do it again, I'd remove the shock. It only takes a few minutes but can save alot of time if things don't go back together easily.
  • ncmountainman
Posted March 10, 2006 - 09:41 AM
:thumbsup:
good deal,now everyone can just look up the part #'s for 06 and get a set :thumbsup:
  • Drfletcherdc
Posted March 11, 2006 - 03:24 PM
I was wondering after installing the quickshot, where was most people setting their pilot screw?
  • 10 replies
  • Hot  47 replies
  • 5 replies
  • On January 15, 2017
