Yz450f rear sprocket probs
6 replies to this topic
  • boyonblue52
Posted March 09, 2006 - 10:29 AM
A my freind has a 2003 yz450f...the same bike as mine and he has had problems lately and in the past where he would sheer the rear sprocket bolts right off! He has tried thread lock and everything but every once in a while he will sheer them off. He rides the bike like a pro...and does pretty well and so i was wondering if there would be a solution to this or if anyone has had the same problems
  • xtreme165
Posted March 09, 2006 - 10:34 AM
Replace all the YZF sproket bolts with CRF sproket bolts and nuts. My 03 had and alot of other's on newer YZF have had the same problem which usually results in a destroyed hub. So go get some CRF sproket bolts and and get rid of the stock ones asap!
  • aford541
Posted March 09, 2006 - 09:02 PM
OE Yamaha bolts will work you have to tighten the crap out of them & if they break they would have anyway.
  • SureBlue
Posted March 09, 2006 - 09:15 PM
Try GYTR titanium bolts and tighten the crap out of them.
http://www.yamaha-mo...1/2006/0/1.aspx
  • TexN343
Posted March 10, 2006 - 04:16 AM
I used the stock one and I have about a half inch eaten out of my swing arm due to the lil bast*rds coming loose. Definitely use the almost permanent lock tight
  • xtreme165
Posted March 10, 2006 - 04:48 AM
TRUST ME! Save your self the headache and $$$$ and get the CRF bolts!! The stock Yamaha ones are JUNK! You will not have to piss with the CRF sproket bolts and they fit perfect. Don't listen to the other BS "stock ones will work" BS, yes they will work but for how long. I own 2 motocross tracks and have seen at least a dozen rear Yamaha wheels destroyed from the sproket bolts coming loose. The KX 250 bolts work as well. Take the Yamaha ones out and go get the CRF or Kx sproket bolts. I have a 06 Yam. and I will changing them over once I start to ride.
  • DPW
Posted March 10, 2006 - 05:42 AM
http://cgi.ebay.com/...1QQcmdZViewItem
  • On January 15, 2017
  • Hot  47 replies
  • Hot  30 replies
  • Hot  36 replies
