forks
4 replies to this topic
  • Trees4Traction
Posted March 09, 2006 - 08:06 AM
is it hard to change the oil in the forks or what
Posted March 09, 2006 - 08:53 AM
http://www.thumperta...ad.php?t=348624
http://www.thumperfaq.com/fork_oil.htm
Info applies to '04 and earlier models.
  • RD73
Posted March 09, 2006 - 10:44 AM
If the seals need to be replaced, is the process different from that described in the above link? After my last ride, I noticed one fork was leaking.
Fork oil, seals, and what else is needed?
Posted March 09, 2006 - 10:59 AM
A little, different, yes. The process for replacing the seals is listed here:
http://www.thumperfa.../fork_seals.htm
Again, this is different on the '05 and up YZ's and '06 WR's.
Note that once you get the fork tubes separated, you have gone as far as you absolutely have to, and there is no strict need to remove the base valves or damper cartridges except that it allows a better cleaning, if that's required. I generally don't do it just to replace a seal.
  • RD73
Posted March 09, 2006 - 12:09 PM
Thanks!
  • Hot  47 replies
  • Hot  50 replies
  • Hot  30 replies
  • Hot  113 replies
