2003 WR450 Midrange hit ?
13 replies to this topic
  • Poway1464
Posted March 08, 2006 - 07:46 PM
I recently purchased a 2003 WR450. I was told that it had all the FREE mods performed plus the YZ throttle. While in 3rd gear and hitting the throttle hard, it bogs and stutters. Rolling on the power - power problem through the gears. Low end power, nice and snappy (for a WR) no problems.
I remember something about WRs having a governor on them, is this what I am experiencing?
Larry
  • new2blu
Posted March 08, 2006 - 07:49 PM
From the way it sounds you have some jetting issues. Take care of those and you will love the bike.
  • Poway1464
Posted March 08, 2006 - 07:59 PM
Well it the jetting was done and set up for the PC496 pipe. I have the paperwork. And I do like the bike already, from a CR250 to this was a real nice transition. I LIKE IT !!
  • dbailey223
Posted March 08, 2006 - 08:07 PM
Maybe the jetting was done but not right? It's worth playing with the carb a bit to take the jets out and post what they are here, and then you'll know for future reference to.
  • dbailey223
Posted March 08, 2006 - 08:08 PM
Maybe the jetting was done but not right? It's worth playing with the carb a bit to take the jets out and post what they are here, and then you'll know for future reference too.
  • Poway1464
Posted March 08, 2006 - 08:45 PM
Work was done by Baja Designs
162 Main
45 Pilot
Zip-Ty FCR Fuel Screw
Since this is a 2003 and I have only owned it for 3 weeks, the carb could need servicing/cleaning and maybe a new set of jets.
  • clark4131
Posted March 08, 2006 - 09:24 PM
Eureka! That's the problem, you're WAAAAY too lean. I'm assuming by your name your in North County, right? If so, then you're probably real close to sea level so you're going to need a 48 pilot and 168 Main. Run your neelde clip in the 4th position from the top and give her a spin. Write back with your findings :thumbsup: ...SC
  • pkcof
Posted March 08, 2006 - 11:42 PM
sea level ~ 5000' here in Australia.
#48 Pilot
OBDUS Needle (third clip pos)
#172 Main
GYT-R Exhaust + all free mods (inc grey wire)
Giddy-up !!!!!!!
  • Dirtmizer
Posted March 09, 2006 - 02:31 PM
Check out the jetting data base at the top of this forum for comparison , lots of good stuff.
  • Poway1464
Posted March 09, 2006 - 04:53 PM
I reviewed the D-Base and it appears that the consensus is 168 Main and 48 Pilot. It sounds like a good place to start. And the shop has the jets in stock.
Might go buy a lottery tix.
  • tigerowner_ut
Posted March 10, 2006 - 03:43 PM
May want a JD jet kit. THat way you are set for wherever you go. You can get it here on thumpertalk.
  • Dan_Lorenze
Posted March 10, 2006 - 03:58 PM
Yes my friend.... the 48 is key and either a 168 or 170 is what you want as the main.. You're golden..... :thumbsup:
  • Poway1464
Posted March 10, 2006 - 08:37 PM
What kind of disappoints me is Pro Circuit. I have worked with jet skis and many of the pipe manufacturers (Factory Pipe, COffman and Riva) would have jetting recommendations on their website. Pro Circuit pretty much tells the customer to 'pound sand, don't bother us'. Pretty sh&tty attitude PC !
So everyone should buy FMF?
  • Poway1464
Posted March 11, 2006 - 04:37 PM
Well the guy gave me the wrong info. It had a 155 main versus the 162 that his notes had. I installed the 168 main and what a difference that made - wow! But that was on the street so we will see how everything works at Ocotillo.
Thanks everyone.
L.
