XR400 vs Xr600 rear wheel vs. XL
8 replies to this topic
  • SanJoseWR450F
Posted March 06, 2006 - 10:35 PM
Is a 96 XR 400 rear wheel different from a 96 XR600 rear wheel? How about an XL wheel, besides the cush drive, will an XL wheel fit on a XR? Thanks.
  • targetdrone
Posted March 06, 2006 - 11:24 PM
No. The XL wheel is wider by about a half inch.
  • SanJoseWR450F
Posted March 07, 2006 - 09:47 AM
Thanks about the XL wheel. How about an XR400 vs. XR600, are the rear wheels the same or different?
  • Phuzzy McPhuzzface
Posted March 07, 2006 - 11:04 AM
Not sure, but my:
'93 250R rear is a 18x1.85 (front is a 21x1.60)
'06 L rear is a 18x2.15 (front is a 21x1.60)
I was kinda hoping they might be interchangeable, in the off-chance I'd want to add pure dirt skins to the L. The fron looks like it might swap, speedo/odo drive included. I still have to verify it, though.
  • SanJoseWR450F
Posted March 07, 2006 - 03:11 PM
Thanks, I am hoping the hub is at least the same from XR400 to XR600. I'm converting an 89 drum brake XR600 to disc brake and I seem to be able to find a lot of XR400 rear wheels and no XR600 wheels. I can always lace a new rim on it.
  • Blade Man
Posted March 07, 2006 - 04:11 PM
you can look in bikebandit.com and compare part #s
Very usefull to see what fits what if the part #s are the same.
  • slomotobug
Posted March 07, 2006 - 05:05 PM
XR400 wheel should fit, they fit my 650 as long as I use the 400 caliper mounting bracket because the rotor is a different size, but the calipers are the same, and the hubs are the same size. Aslo a CR250/500 rear wheal are the same hub/rotor size, till you get into the aluminum frame 250. :thumbsup:
  • LotsOfBikes
Posted March 07, 2006 - 09:54 PM
The XR650L rear wheel does not have cush drive. It is interchangeable with the XR600R, as I have done before.
  • byron555
Posted September 14, 2008 - 06:52 AM
XR400 wheel should fit, they fit my 650 as long as I use the 400 caliper mounting bracket because the rotor is a different size, but the calipers are the same, and the hubs are the same size. Aslo a CR250/500 rear wheal are the same hub/rotor size, till you get into the aluminum frame 250. :excuseme:
Could you put a xr650L rotor on the xr400 rear hub instead?
