NOST valves
No replies to this topic
  • ncmountainman
Posted March 06, 2006 - 08:35 AM
anyone with an 06 WR wanting to try the NOST 4 way(hi,mid,lo,suppleness) adjustable base valves? if so i'll trade them for your stock ones(must be 06); they are barely used and go for $280 new. i tried them with my new CV replacement and found that they were not meant for each other due to the change in pressure. the adjustment on these things is amazing. i need the 06 BV's because i think the HS bypass circuit might work better with my CV replacement. i have the 14mm allen socket to remove them i can send if you have a impact gun :thumbsup:
