Am I doing damage
3 replies to this topic
  • nurooi
Posted March 06, 2006 - 06:41 AM
Hi All,
Once again in my infinite wisdom I did my impression of the flying canonball over the handlebars. Once the embarrament had subsided, I looked over the bike and noticed I had damaged the header pipe.
I have fixed the dent in the headerpipe as per the forums instructions (thanks to all the posts on removing dents). However, I me thinks the pipe actually bent as well. I installed the GYT-R muffler and have noticed that it touches the frame (Blue vertical bar). If I move the entire exhaust and re-bolt it, it still touches the frame. I have ridden like this for a couple of weeks and other than the bar getting hot, nothing else seems wrong.
Your advice please.
Regards
Nurooi :thumbsup:
  • Indy_WR450
Posted March 06, 2006 - 10:31 PM
replace it with a SS aftermarket header. The stock Titanium unit will only get worse as it heat cycle fatigues. :thumbsup: I went thru 4 of them so I know they only last about 30 weekends before a pebble can ding them in! :thumbsup:
  • nurooi
Posted March 08, 2006 - 06:02 AM
Hi Indy,
Thanks for the reply. Any ideas of makes / models of the aftermarket headers. Where I am from they would not know what I am talking about so I will probably need to do a postal order.
Once again - thanks
Nurooi
  • Indy_WR450
Posted March 08, 2006 - 08:13 AM
You can order the YZ426 stock header which is SS but the heat shield is a different design and mount or you can get a powerbomb SS SX header from FMF. :thumbsup:
