Any DR600 owners?
Posted 02 September 2008 - 08:41 PM
Posted 02 September 2008 - 08:44 PM
Cheers
Posted 03 September 2008 - 07:45 AM
Posted 03 September 2008 - 05:16 PM
Why did you jump in any way now I wont get any help by the way Im not no wanna be you are.
Thanks alot Richard
Posted 04 September 2008 - 11:34 AM
Posted 04 September 2008 - 11:59 AM
Posted 04 September 2008 - 12:16 PM
Posted 05 September 2008 - 01:50 AM
I am having a hard time seeing what your problem is.
I offered Larkin assistance with the rebuild of his SP/DR600 as I have a workshop manual in my possession.
He sent me a pm for some spec's, which I duly sent. (and am more than happy to do the same for you.)
I then noticed in a later post he also rode a Harley. I thought it was a coincidence that, despite being on opposite sides of the planet, we had the same type of machines.
I thought that posting a pic of my Harley was a perfectly appropriate thing to do, to show we had a similar interest, maybe even creating a "bond" of sorts with a fellow rider on the opposite side of the Earth.
Obviously, you disagree........and thats fine, each to your own.
The main problem I have is that in the digital world, it's very easy to mouth off at people, re, "fat cat lots o cash no style lazy ass Harley hells angels wanna be's.", and not get a punch on the nose like in the analog world.
You don't know me, and you don't know the other fellow, so might I suggest you
relax a little, have a beer, and let it go.
Cheers
Posted 06 September 2008 - 02:41 AM
Posted 06 September 2008 - 03:25 PM
There's no gasket on the rocker cover.
Best to take it off, clean the surfaces and reassemble with Three-bond.
Cheers
Matt
Posted 07 September 2008 - 12:31 AM
Cheers
Matt
Cheers
Posted 09 September 2008 - 11:55 PM
I want to motard my DR600. If anyone has any info or pics and any ideas, please post
I saw this on bikepics.com and like the look of the front end.
Apparently its from an R1. Has anybody done anything like this, or know any matches that i could look at?
What exhausts have people put on theres? I currently have a badly rusted can with baffle rings at the end, what have people found that match and is a good swap.
Cheers
Adam
Posted 22 September 2008 - 03:08 PM
Posted 03 October 2008 - 01:41 PM
Posted 04 October 2008 - 03:40 AM
By the way, she's almost registered now, just gotta pay the RTA the money. Front rim has a bit of a flat spot so I'll have to straighten or replace it for those long rides. Yee-haa!
Posted 04 October 2008 - 08:23 AM
Posted 04 October 2008 - 03:42 PM
The manual decompression lever is next to the clutch lever, cable runs down to the front right hand side of the rocker cover where there should be a spring loaded lever. You could probably rig up a BMX brake lever and cable to do this. Without it, I'd have no hope of kicking over the bike. Looks like in the photo your tank has a few dingles. I'm about to work on mine as the steering stops have been ground off and bark buster brackets have smashed into the tank. If you get yours straightened out before me, let us know how, just to give me some pointers eh?!
Posted 04 October 2008 - 05:31 PM
Posted 05 October 2008 - 02:46 AM
Manual decompression cable goes from here to the left handlebar.
The only seal here is for camshaft, easy to fix leak with gasket glue.
The only seal here is for the auto decompression lever. If this or the manual one on the other side leak, do what I did, remove the rubber seal and the spring inside it [if it has one], then make up a new spring out of some wire like a keyring piece of steel. Make it fit snug around the rubber and test it on the shaft to see if it seals nicely. If so, whack gasket glue around it , fit it back in and oil leak fixed. Mind you, this may be a temporary or dodgy fix but mine has done okay for over 100km now, no sign of seeping at all. It's all about getting pressure on the surface of the rubber and steel.
If the seal you're talking about is inside the rocker cover, it's most likely valve seals. There is a website somewhere that lists Suzuki part numbers and diagrams. Might take a bit of searching but you can find it. I did.
Cheers. EDIT - I can't get the pictures bigger, software [alcohol] related issues so if you need more clarity [claret] then let me know. BTW I have started boggin up my tank with putty, getting close to original shape now. just need the colour.
Posted 05 October 2008 - 05:59 AM
larkin35 said:
I actually tried to get some pattern seals from my local bearing shop & he said they were made of a non standard material, he could get normal urethane ones, but they are only designed for temps upto 100 C, so get the genuine ones. I think I paid about £10 UK for the pair.
