james dean
5 replies to this topic
  • higgy426
Posted September 28, 2001 - 04:37 AM
James
You replyed to my big problem please help which i am gratful but what did you me about plate on wrong?
thanks
mike
  • Hick
Posted September 28, 2001 - 06:33 AM
JD was referring to the slide plate I believe. I’ve never noticed, but Boit on the YZ side discovered that it was possible to put it back in upside down. I imagine this could cause some weird carburetion problems.
Hope this helps.
  • James_Dean
Posted September 28, 2001 - 06:51 AM
Thats right, the throttle slide has a plate facing the engine. A few guys have taken the slide and plate apart for cleaning (or curiosity) and put the plate back in upside down causing problems that couldn't be cured.
  • higgy426
Posted September 28, 2001 - 07:00 AM
problems that couldn't be cured until he put it in the right way?
  • Taffy
Posted September 28, 2001 - 07:25 AM
the right way up?
the little cutaway should be at the bottom and the height of that cutaway measured against the edge of the kitchen table is 1.5mm
amen
Taffy
  • James_Dean
Posted September 28, 2001 - 12:06 PM
Yes, after turning it right side up the problem was corrected. It will never run correctly upside down.
