Gray wire mod
10 replies to this topic
  • odonnks
Posted March 02, 2006 - 05:05 PM
Is I understand it the gray wire mod, (opening the gray wire circuit), remaps the timing curve to the YZ spec. I'm assuming this YZ curve is more quickly advanced.
With the heaver WR flywheel I would think it cold lead to pinging or even less low end torque.
If this is the case what are the benifits of the gray wire mod to a WR?
I recently did it to mine but its too slick from snow and ice to really test it out.
Any thoughts?
Thanks
  • Matty05
Posted March 02, 2006 - 05:09 PM
Any thoughts?
Ride harder!!! :thumbsup:
If you haven't done the throttle stop mod, it won't do anything.
  • odonnks
Posted March 02, 2006 - 05:31 PM
I have done the T-stop mod.
Even so, if any engine timing advances faster then the engine can spool-up it'll stumble and possibly jus fall on its face.
I've messed with advance curves on 2 and 4 strokes and seen this happen.
Maybe the YZ curve is not much more advanced but I don't know.
Thats why I'm asking.
I will try to ride harder but I'm still curious.
thanks
  • Matty05
Posted March 02, 2006 - 05:54 PM
It is fine, just your jetting will cause it to run like crap.
  • MotoRick
Posted March 02, 2006 - 06:31 PM
On an engine where spark timing is determined by input from crank and throttle position sensors, this isn't a problem. The ignition module will correct for engine RPM and load.
  • Captain Bob
Posted March 02, 2006 - 07:09 PM
Any thoughts?
Thanks
If you search on this list, you will find that it has been stated that by disconnecting the grey does change to the YZ fuel map which results in higher top end power but less low end. How much I do not know. I have a YZ timed WR 400 which has not had the grey wire mod completed. I am going to leave it like that because I am satisfied with the low end power and do not want to change it. I am in New England which is mostly tight rocky single track where low end is important. I will say however, that I have not done the grey wire mod to test the validity of this.
Hope this helps!
Bob
  • bg10459
Posted March 02, 2006 - 07:12 PM
http://www.thumperfa...m/gray_wire.htm
  • Matty05
Posted March 02, 2006 - 07:25 PM
Hope this helps!
Bob
It doesn't effect bottom end.
  • MotoRick
Posted March 02, 2006 - 07:48 PM
Nope, not a bit. The only purpose of the gray wire and longer throttle stop is to allow the WR to pass EPA drive by sound regulations. Nothing more.
  • boer
Posted March 03, 2006 - 05:38 AM
Do the gray wire, throttle stop and all other "free mods" :thumbsup: you won't look back, that's guaranteed. I felt more power from idle to flat out :thumbsup:
  • odonnks
Posted March 03, 2006 - 09:14 AM
Good stuff. I didn't see the link to the timing curves.
Thanks
