Oil Filter Allen Screw
6 replies to this topic
  • broncomoto
Posted February 28, 2006 - 11:43 AM
Whats the trick for keeping the oil filter allen bolt from stripping?
  • jbrooks26
Posted February 28, 2006 - 11:50 AM
No trick, just don't over tighten it. It doens't need to be gorrilla tight, just snug plus about 1/4 turn. Hope this helps.
Josh
Posted February 28, 2006 - 01:16 PM
Actually, there is a trick: Ignore the manual. At least, ignore the part about using the oil filter Allen bolt as a drain for the oil filter well. Doing this runs metal chips from around the filter through the threads in that hole, and those chips then wear and damage them. The trick is to just remove the cover and dump the oil out that way, so that as little as possible will run down through the threads.
  • broncomoto
Posted February 28, 2006 - 01:45 PM
Thanks.
The first time I drained the oil and changed the filter (I do this after I ride for an hour or so) the screw was resisting, so I was pissed. I'm hopeful that even with the frequency I change the oil (from lessons learned) I'm not helicoiling my new steed anytime soon.
Anyone else want to weigh in? Scott's oil filters - discuss.
  • MotoGoalie
Posted February 28, 2006 - 01:58 PM
Mine was stripped when I bought the bike used. I got a new one and thankfully the cases weren't boogered up. I just gently snug it up now. I follow grays advice and always change out the filter, never use that bolt just to drain oil.
  • jbrooks26
Posted February 28, 2006 - 02:12 PM
I stand corrected!! I never thought of it this way, probably because I always felt that it was too easy to change/clean the filter not to do it along with every oil change. This makes sense though, Thanks grayracer.
Josh
Posted February 28, 2006 - 04:24 PM
Hijack your own thread? Hey, it's yours. :thumbsup: :thumbsup:
I use a Scotts in both bikes. They've paid for themselves at least twice over.
Read:
http://www.thumperta...tts#post2796978
  • Hot  47 replies
  • Hot  113 replies
