Crack in float bowl
4 replies to this topic
  • charliep
Posted February 27, 2006 - 07:06 PM
I have a small crack inside my Keihin FCR carb. Its above the drain screw. I guess I tightened the screw to tight. Am I the only idiot to do this?
Where can I buy the bowl? Any suggestions? Sudco wants $150.
I thought I would post, I dont want anyone else to do this. I'm so stupid!! :thumbsup: :thumbsup:
  • clark4131
Posted February 27, 2006 - 07:40 PM
Be aware that Sudco's likely does NOT have a leak jet, so your AP timing will be a beeotch to dial in. I'd double check with them before you pull the trigger. JD Jetting advertises a Float Bowl w/ Leak Jet for $60, so I'd give them a call before you do anything else. If you go OEM, you have to buy a whole new carb :thumbsup: ...SC
  • JSanfilippo
Posted February 27, 2006 - 10:13 PM
JB weld that son-of-a-bitch
  • Numskull
Posted February 27, 2006 - 10:59 PM
:thumbsup:
  • charliep
Posted February 28, 2006 - 08:19 PM
SC, thanks for the info.
I thought about JB weld but, would feel better with a new bowl.
thanks again
