need help with starter upgrade 03 wr450f
1 reply to this topic
  • nuggets18
Posted February 27, 2006 - 05:54 PM
are they any more recent upgrades for my starter. other than the 04 upgrade
and if I replace my starter can I use an 05 starter and is it upgraded from the 03 starter or is the same starter??? if I do the upgrade should I also replace the starter clutch behind the flywheel? I am still running with the stock starter clutch. and are there any tricks for removing the bushing from the side cover???
  • Indy_WR450
Posted February 27, 2006 - 08:14 PM
Follow my instructions on this web site:
http://www.wr450.com...inals/index.htm
You dont need to remove a bushing but rather add it to the 03 cover. :thumbsup:
05/04/03 should use the same starter motor. :thumbsup:
Replace the one way starter clutch if it falls apart when you remove and inspect it. :bonk:
