valve adjustment
7 replies to this topic
  • hurtigrodfare
Posted February 26, 2006 - 02:55 PM
I acquired a xr650r 2002 real cheep. One thing it would not run. Last thing to check is the valve adjustment. Just need to know if you set the valves on the timing mark or one of the other marks on the fly wheel.
  • brichter
Posted February 26, 2006 - 03:39 PM
Set it on the T mark.
  • hurtigrodfare
Posted February 26, 2006 - 04:15 PM
thank you
  • HawkGT
Posted February 26, 2006 - 05:30 PM
Just remember to use the T mark when it's on the compression stroke. If you just rotate around and line up the T you've got a 50/50 chance of being on either the compression stroke or the exhaust stroke.
  • wr450fyamaha
Posted February 26, 2006 - 06:36 PM
Does that apply to an L? if so, how would I make sure its on the compression stroke?
  • creeky
Posted February 26, 2006 - 06:50 PM
PUll off the rocker arm caps and watch the intake valves. When the intakes start to close, the piston is coming up on compression. Look closely at the marks, the ''F" and "T" marks are easily confused.
  • cmwoody
Posted February 26, 2006 - 06:56 PM
Valves will all feel loose, wiggle when you grab hold and shake'em around a bit if your on the compression stroke.
  • wr450fyamaha
Posted February 26, 2006 - 07:22 PM
makes sence......you would have a serious problem on your hands if they didnt wiggle a bit...
  • Hot  186 replies
Washington
  • Hot  32 replies
  • 22 replies
  • Hot  29 replies
  • 3 replies
