aftermarket fuel screw
5 replies to this topic
  • moab39
Posted February 22, 2006 - 07:20 PM
Do the aftermarket fuel screws tend to give you the feeling that they could loosen, I know that there is more leverage. I am coming off a 2 stroke, and wonder if you need to mess with a 4 stroke more or less . I ride between 4,000 and 11,000 ft. on my yz 250 I would only have to adjust the air screw a quarter turn depending on temp , and of course a main jet up or down. After looking around the carb on my 06 wr I don't want to mess around any more than I have to. Also how far out do most of you have your fuel screws set at and with witch pilot jet thank you.
  • twenty34
Posted February 22, 2006 - 07:22 PM
you can buy a fuel screw from the TT store and will be easily adjustable. I used one for a CRF and it works fine. Easy access. When you do the free mods, you will want to have the aftermarket fuel screw to dial it in.
  • dbailey223
Posted February 22, 2006 - 09:15 PM
Some have reported aftermarket fuel screws getting loose. Something about some being manufactured a bit wrong. So, I think it is possible frlom what I have read here.
  • Ripmeister
Posted February 23, 2006 - 10:18 PM
Partial reply -
I'm sure it's possible - but putting the aftermarket screw in was one of the best things I did with my bike :thumbsup: especially with the altitude diff you're talking about. I can't remember the setting and it's too late to go check - I ride mostly at 4500 to 6500 feet and I just followed directions on dialing it in. I love it because when i do ride at higher elevations, it's really simple to get by for a few days without messing with the other things.
And IMHO I think you'd want it as much for the four stroke as the two stroke.
  • 426_Texan
Posted February 23, 2006 - 10:24 PM
Take a peek at this post in the YZF forum:
http://www.thumperta...ad.php?t=343272
  • tmckeown
Posted February 23, 2006 - 10:28 PM
Hi,
I bought a Zip-Ty fuel screw. O-ring on that shrunk after first ride so that I can't use it any more :thumbsup:
Just haven't have energy to go and get a new one which can take engine heat
Timo Mc
