Hard to find neutral with engine running
4 replies to this topic
  • johunter666
Posted February 21, 2006 - 05:32 PM
Have 05 Wr450. Approx 800 miles on it. No abuse. Have done many oil/filter changes using Yamalube. Having trouble finding neutral while engine running. No other shifting problems. My clutch is adjusted properly. Does this hot or cold. Any ideas?
  • Matty05
Posted February 21, 2006 - 06:44 PM
It is all you!
Just put slight pressure on the gear lever, you want it to click out of 1st, not go to far and click into 2nd. You will get the hang of it.
  • bigdrtrdr
Posted February 21, 2006 - 06:51 PM
You might also have just a bit to much freeplay at the lever.
Eric
  • Dirt_rebel
Posted February 21, 2006 - 09:18 PM
try the 79cents thumperfaq clutch fix mod..it helps alot..
here's the link: http://www.thumperfa...clutch_mods.htm
  • ShadyatBest
Posted February 21, 2006 - 10:37 PM
just read that tip, very good idea
