Oil mix ratio on a Blaster
11 replies to this topic
  • Big Pond
Posted February 20, 2006 - 06:48 AM
[COLOR=Blue]I got Yam 200cc ATV Blaster, it has a 2 stock oil reservoir to mix in with the fuel.[/COLOR]
I was riding flat out when for a moment it lost power. :eek: I stopped let it cool then continued on much slower. I guess it wasn’t getting enough 2 stock oil? :thumbsup:
:bonk: I went to Yamaha and asked them[COLOR=Red]…"It user as much as it needs”[/COLOR] :bonk: (he must have been factor trained). :eek:
I measured of the oil bottle, kept a log of fuel and oil used over time. :thumbsup:
I am using 100mm of oil to 10 liters of fuel, ie 100:1 mix. :p
I asked my friend he said Yamaha Outboards used 100:1 mix but he could tell me if that was normal for my bike?? :bonk:
Have I got a problem with the oil pump? :p
How much oil dose the blaster use? :lol:
  • LostTrail
Posted February 20, 2006 - 07:12 AM
100:1? You should be using 32:1.
  • DOIWANTATHUMPER
Posted February 20, 2006 - 08:11 AM
the yamaha blaster is a oil injected bike, you put oil, Yamalube 2-s, in the tank under the seat... then you put gas in the tank... you dont have to worry about mixing anything... the only reason you would ever have to mix is if someone removed the oil injection system and put a block off plate on it. if your oil injection system has been removed then you want to mix at 32:1.... thats 4 ounces of oil for every 1 gallon of gasoline... and you mix them in a seperate container... do not attempt to mix the gas and oil inside the blasters gas tank and then shake it around... and thats about it... good luck...
  • skoot22
Posted February 20, 2006 - 09:16 AM
:thumbsup:
  • Big Pond
Posted February 21, 2006 - 12:55 AM
Thanks for that info.
Its seems that I have a problem with the oil pump!
Is there any serviceable part in this oil pump unit?
Cos I think a new one cost something like $100.
  • NYMXer
Posted February 21, 2006 - 06:09 AM
There is a plate you can buy that blocks off the injection pump. You just run premix. The good thing about premix is you know it's getting oil. Blaster pumps do fail, not often but it isn't rare either.
  • DOIWANTATHUMPER
Posted February 22, 2006 - 02:46 PM
ive been working in a yamaha dealership for 3 years now.. not once has someone brought a blaster in for oil injection system failure.... not saying it doesnt happen, but its very uncommon.... i have however sold about 3 block off plate kits... just for people who prefer to save weight by removing the oil pump and also making sure they can mix lean for power or rich for protection... mostly racers remove the pumps... if somehow your pump went bad... id block it off for cheap... rather than buying a new pump for 100.00 ... if i remember correctly the block off kit is about 32.95... good luck...
  • SirHilton17
Posted February 22, 2006 - 03:08 PM
i have a bike with oil injection... i got rid of it... i completely removed the gear in the tranny that runs the pump, and made a block off plate to go into place of the pump...
i dont know if the blaster is set up with a specific gear that runs the oil pump, but on this there was so i just did it there too... less drag on the engine, not much, but every little bit helps
  • 356
Posted February 25, 2006 - 11:14 PM
Quite a few people have had oil pump failures here. :thumbsup:
  • Big Pond
Posted March 04, 2006 - 06:12 PM
Thank guys for all the info. :thumbsup:
I am going to leave the oil pump on the bike which is supplying a 100:1 oil mix and make up the shot fall with pre-mix in the fuel to 32:1. :bonk:
Why you ask, so if I ever forget the per-mix a lease the motor will be getting some oil. :thumbsup:
:bonk: Once again thanks. :bonk:
  • LostTrail
Posted March 05, 2006 - 06:56 AM
That sounds like a bad idea.
  • DOIWANTATHUMPER
Posted March 06, 2006 - 11:56 AM
a little bit of extra oil never hurt anybody... i dont think the oil injection system is set up for 100:1 ratio though, unless perhaps thats the ratio per "squirt" of oil/gas going into the cylinder... 32:1 is fine even if you are using the oil pump... it may bog a little bit, and probably smoke more, but it will increase the longevity of the motor due to extra lubrication.... i think if it was me, and i was running the oil injection system and pre mix... i would mix more like 50:1.... a little less oil, still enough for safe protection, considering you dont even have to run pre-mix on this bike.... good luck....
YZ 125 fouling plugs fast! by bustech17
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • Hot  31 replies
yz250 help please.. by smokedaddy
  • Hot  32 replies
05 YZ 250 Build by Moto_Ty
  • Hot  158 replies
Is the stroke coming back? by MazdaMan
  • Hot  73 replies
2002 yz250 transmission assembly by Neilmccown
  • Hot  62 replies
