Weird cover on the bottom of carb
13 replies to this topic
  • kid on a 426
Posted February 19, 2006 - 02:52 PM
Me and my dad were out in the garage adjusting the pilot screw because it was way too lean so he's looking down there and there's a red cover on the very bottom of the carb and it's not a magnetic drain bolt its behind that if no one know's what it is i might be able to post some pics. I think the brand is factory r and d but its really hard to read and i cant find it on google
  • Yak
Posted February 19, 2006 - 02:57 PM
Factory R&D P-38 Accelerator Pump cover.... :thumbsup:
  • kid on a 426
Posted February 19, 2006 - 02:59 PM
wow thanks for the help so fast do you think that may have contributed to it running waaayyyy too lean even with a queit core in
  • Yak
Posted February 19, 2006 - 03:08 PM
No probably not. what throttle position is it running lean at?
  • kid on a 426
Posted February 19, 2006 - 03:13 PM
Well we fixed it pretty good now but before when u just give it a little gas above idle and let off it would make huge popping noises but we just backed out the fuel screw a bit and its almost completely gone. i didnt know that that little screw made such a big difference now im thinking of getting like a zipty easy adjust one
  • kizzle426
Posted February 19, 2006 - 04:02 PM
Yeah, I just got my Zip-Ty not too long ago and I love it. Just be sure before you adjust it you let it warm up completely. A lot of times mine will pop when it first starts but it calms down after a couple of minutes.
  • donutman126
Posted February 19, 2006 - 10:04 PM
does the pump cover do anything or is it just for lookks
  • JSanfilippo
Posted February 19, 2006 - 10:40 PM
How many turns did you turn the fuel screw out?? Sounds like you need to go up a couple sizes on the pilot jet
  • kizzle426
Posted February 19, 2006 - 10:45 PM
It makes the fuel spray into the mix faster. Yes it makes a difference especially on 400/426's as well as the BK mod.
  • kid on a 426
Posted February 19, 2006 - 10:48 PM
Like 1 and a half i think my dad said
  • JSanfilippo
Posted February 19, 2006 - 11:33 PM
Maybe one size?? Then again I shouldn't talk outta my ass like this because I am familiar enough with the FCR carb to be giving jetting advice but from what you described in your original post it sounded like it was lean on the pilot jet :thumbsup:
  • kizzle426
Posted February 20, 2006 - 12:51 AM
If you have to go over 2 turns in either direction, you either need a size up or a size down. 1 and a half is about what I run.
  • kid on a 426
Posted February 20, 2006 - 05:46 PM
ya it pops a tiny bit when im flying down a hil and using the compression braking but thats probably only because its cold out
  • kizzle426
Posted February 20, 2006 - 05:51 PM
A little bit of popping is completely normal. That's just back pressure.
  • 9 replies
  • 0 replies
  • Hot  33 replies
