trip meter not working
1 reply to this topic
  • charliep
Posted February 17, 2006 - 09:07 AM
My trip meter did not work after I had my front wheel off. Is there a trick to putting on the gear at the hub?
Any suggestions? thanks.
  • freestyle250
Posted February 17, 2006 - 09:31 AM
Your hub has two notches on it that match up with two notches on the inside of the odometer. just make sure you have it on straight. Its pretty hard to put that on in a way that it wont allow the notches to catch. make sure your axle is in all the way, and the wire is is screwed in at the top. Also, check up by the odometer screen, and make sure you dont have the rolling knob pulled out.
