NEED HELP!!! '03 Cam mod
33 replies to this topic
  • CAVSCOUT96
Posted February 18, 2006 - 10:22 AM
#21
yeah but finding the guages was the hard part. I check everywhere I could think of. Next option was to drive 45 minutes to Louisville to MAYBE find the guages. It became a time issue. I needed to get her buttoned up. I was supposed toi ride today, but it snowed 3.5 inches overnight, and the roads are in bad shape so I'm stuck at home anyway!!! :thumbsdown:
  • byggd
Posted February 18, 2006 - 10:28 AM
#22
I guess I got lucky. I went into my local dealer (Malcolm Smith) and they had the shims in stock and the gages hanging on a spinner rack by the parts dept. I guess it makes a difference when the owner is one who actually rides, they know what to stock :thumbsup:
  • CAVSCOUT96
Posted February 18, 2006 - 10:32 AM
#23
YEah, That's about the only reason I can think of to live in CA!!! tons of tracks and more STUFF for bikes. KY is quad heaven, and bikes are secondary. TX (HOME) is very bike friendly, but sometimes you have to drive to AUS, HOU or DAL to get into some of the specialty stuff.
  • WheelsUp
Posted February 18, 2006 - 11:58 AM
#24
http://www.griotsgar....x=0&search.y=0
Available 3/6.
$8.99, and I think he gets $7 for shipping, so they're not cheap, but they are "right"
  • CAVSCOUT96
Posted February 18, 2006 - 12:15 PM
#25
Thanks!!!
  • tom00013
Posted February 19, 2006 - 07:14 AM
#26
The YZ cam is identical to the WR cam except that the decomp pin is 3mm shorter, and the cam is indexed differently so the timing marks STILL line up.
The only time you change the pin count is when you change the stock '02 or older WR can to give you YZ timing without autodecomp.
I THINK the 4xx engines have 14 pins between marks.
Let me get this straight-no matter which cam ('03 stock yz or wr)is used in an '02 or earlier wrxxx, the pin count will be 14??
Also, how does the 3mm shorter pin on the yz cam effect the compression release-or is the cam designed different on the yz that this allows the same amount of effort to start the yz as the wr.
I'm going to do the mod but still am unsure of going the yz or wr route.
Can the '03 wr cam be rotated 1 pin like the earlier non auto cams to get the yz timing or will you lose the autocomp feature by doing this.
Thanks,
Tom
  • WheelsUp
Posted February 19, 2006 - 10:09 AM
#27
Correct... 14 on the 4xx series engines and 13 on the 250.
The YZ cam is indexed to be retarded from the WR cam by the equivalent of one tooth. The cam itself is the same except for where it is mounted to the gear, meaning that the hole for the decomp pin is in the same place.
With the pin sticking out too far and the cam retarded, it holds the exhaust valve open too long on the compression stroke and the engine fails to build enough compression to start.
The '03 and later cams must be installed per design... YZ timed YZ and WR timed WR. You might be able to get away with buying the YZ cam and advancing the timing (go 15 pins) to get WR timing... you'll have a little more compression on the kick, but it should start no harder than a '70s era pinger. I wouldn't do it on a bike with an e-start.
  • tom00013
Posted February 24, 2006 - 03:08 AM
#28
Thanks for clearing that up-all makes sense now.
  • ncampion
Posted February 24, 2006 - 05:50 PM
#29
Here's the answer to keeping the engine on TDC while you mess around getting the cams timmed right. Just thread the bolt in by hand until it securely contacts the flywheel, don't make it too tight.
http://i32.photobuck...um/DSCN3686.jpg
http://i32.photobuck...um/DSCN3680.jpg
  • FriscoKLR
Posted March 03, 2006 - 06:12 PM
#30
Just did the mod on a 2000 Wr400 i picked up afew weeks ago. 14 pins between cam marks and it started on the sencond kick and runs great. Kicked it over in my tennis shoes. One thing I noticed is the timing mark on the crank didn't line up with the cams or the piston at TDC with the bike stock. Thought that was kinda odd.
  • bigdrtrdr
Posted March 04, 2006 - 07:20 AM
#31
I just put the 03 YZ cam in my 01 WR It runs great and all.
Does the auto decomp cam make a little more noise at idle than the non?
My valves are in spec so its not that.
Thanks
Eric
  • FriscoKLR
Posted March 04, 2006 - 07:52 AM
#32
I didn't notice anyhting. You plugged the decompression hole didn't you?
  • bigdrtrdr
Posted March 04, 2006 - 08:50 AM
#33
TT plug
  • RichBaker
Posted March 04, 2006 - 11:25 AM
#34
If you pull the spark plug, you don't have to worry about the crank rotating away from TDC...no compression to fight!
