650R Carb question
10 replies to this topic
  • madxr4
Posted February 16, 2006 - 07:40 PM
Hey guys (snaggle),
I picked up a gently used bone stock '00 the other day and after not having run for over 6 months it fired on the first kick. Yay.
Tonight I'm doing the uncorking but have been halted by the wrong jets.
No matter there and an easy fix in the am but my question is: How do I remove the needle to relocate the clip?
Is it done by removing the linkage and sliding the slide out the top?
I've checked a few sites (BRP et al) to find a tutorial but have come up dry.
My carb experience is exclusive to my lawn mower and about a dozen FZ1 Ivan's jet kits. So, I'm not a total spaz but I have my moments and don't want to go too far down an unfamiliar road only to find I need a special tool or more brain power. At least I could buy the former.
Also, my local shop was stumped by the part number for the carb to head manifold replacement part. (p/n 16211-MBN-640)
I've seen varying methods of uncorking....
One mentions the manifold but no air box mod (removal of a piece of plastic).
Another mentions the air box but not the manifold replacement.
Which method have folks found here to be the most effective?
Thanks for any thoughts!
mark
  • XR4DEZ
Posted February 16, 2006 - 07:54 PM
Just cut out the restriction in the manifold.
  • Max Power
Posted February 16, 2006 - 07:55 PM
If your Honda shop is on the ball , they will understand "power up kit" which includes (Exhaust tip, needle and needle jet, main jet and manifold)
Go to your Honda shop, p/u the "power up kit" for your "00-06 XR 650R"
Let us know when you have these parts. The rest is sooo easy.
  • madxr4
Posted February 16, 2006 - 08:03 PM
Really? Just dremel it out? Any specific shape or the whole thing?
  • madxr4
Posted February 16, 2006 - 08:04 PM
Thanks, but I'm just going to drill out the tip.
  • Mudshark
Posted February 16, 2006 - 08:06 PM
remove the whole thing, just leave a nice smooth finnish.
  • madxr4
Posted February 16, 2006 - 08:10 PM
Thanks guys. That saves some shekkles and driving around.
Now, if I can get the needle out without buggering anything up I'll be home free.
  • Max Power
Posted February 16, 2006 - 08:19 PM
We will be standing by. There is that pesky little spring..... you will be fine. :thumbsup:
  • madxr4
Posted February 16, 2006 - 08:27 PM
Thanks MP.
So, it is just a matter of the linkage and the 'Jesus' spring.
Sounds like a fun little morning project.
I'll let you know how it goes. Hopefully I won't be crying about doing something stupid.
  • HawkGT
Posted February 16, 2006 - 09:21 PM
I remove the set screw that connects the linkage to the big return spring--that makes things easier for me. I also replace the two little philips head screws that connect the linkage to the bottom of the slide with little allan head screws. Those little philips jobbies are too easy to bugger up. Actually, I replaced all the philips head screws in/on the carb with allens--much better (just don't over tighten!).
  • XR4DEZ
Posted February 17, 2006 - 08:51 PM
While you're in there fix the choke flap by either removing the hinged part or buy the PC choke plate.
Honda XR650L 2017
  • 0 reviews
  • Hot  186 replies
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
