Devol radiator guards
30 replies to this topic
  • Norman
Posted February 16, 2006 - 06:07 PM
I installed my Devol radiator guards tonight and I must say, they are pretty cheesey. There is no bracing in the back of them at all, I really dont see what they will protect in a bad crash. To make things worse, my top bolt holding my plastic louver on was real tight so I used a pair of pliers to hold the tab while I loosened the bolt, when the bolt broke loose the pliers jabbed the radiator putting a hole in one of the tubes, small but leaking none the less. I now have my first dab of JB weld on my bike. :thumbsup: I will be watching to see what Works and Unibiker come out with.
  • 642MX
Posted February 16, 2006 - 06:12 PM
My Devol radiator guards protect really well. They have taken some big hits and still look like new. Maybe they have changed the design?
  • jecsr
Posted February 16, 2006 - 07:05 PM
I have also just install a set on my bike and now my shrouds seems really wide. Are yours ?
  • fastbyfrank
Posted February 16, 2006 - 07:13 PM
i have a set of devol radiator guards for my 04 yz450f and i like them, they do have a brace behind them and i believe they increase airflow, they have held up flawlessly and i recomend them to all, they also make glide plates, skid plates, brake guards, lowering links,frame protectors, and some pretty trick brake coolers. http://www.devolracing.com/home.htm
im sorry that your pliers slipped and damaged your radiators :thumbsup:
i hope that the jb weld works for you.
:thumbsup:
  • 642MX
Posted February 16, 2006 - 07:19 PM
No, they fit well. I bet something isn't lined up right if your shrouds are sticking out.
  • joshb
Posted February 16, 2006 - 07:45 PM
i had them on my 125 and they worked well
  • jecsr
Posted February 16, 2006 - 07:52 PM
Can you tell by these pictures what might be wrong ?
I did not have any instructions.
  • PK
Posted February 16, 2006 - 08:01 PM
It's not the first complaint I've heard about them when installed on the 2006 450, I'll wait and see who makes a better set.
  • Pukeballs
Posted February 16, 2006 - 09:32 PM
Mine work great. No problem fitting them to my 05.
  • Norman
Posted February 17, 2006 - 04:33 AM
Ive had them on every bike Ive owned, always been real happy with them, but if you notice on the 06 there is nowhere for a rear brace to bolt up. Not bashing Devol at all, they make great products, I just dont think these are gonna help much.
  • Lizard 1
Posted February 17, 2006 - 04:58 AM
Unfortunately, I think a lot of guys responding have older (Pre-06) YZs. I think the issue is on the new bikes since the shrouds and radiator placement is more of an issue.
I think I will wait for Works Connection's offering. I am sure they'll have one at Indy on display. If so, I'll take some pics...
  • 642MX
Posted February 17, 2006 - 06:00 AM
The inside lip of the shroud is hitting the bolt that connects the rear support to the edge of the radiator. If you look half way down on the edge of the radiator you will see the screw that is holding the shroud out. Looks like a little trimming on the plastic is all you need to do. I hope this makes sense.
  • dolfan
Posted February 17, 2006 - 06:06 AM
I ran Devol for 2 years on my WR250, liked them alot, held up well, but did take a spill the twisted the guard and the rad up pretty good, rad did'nt leak but had to be straightened and tested fixed guard and back on the bike it went...this year thu I am gonna try the Faltland guards just because I like the added support for the radiator that comes with them, it has a support for the back of the radiator, looks like good stuff...only reason I switched to them..
Bob
  • mtrdrms
Posted February 17, 2006 - 06:43 AM
Last night I installed a set on my 06 and let me start by saying they seem to be very durable and the installation was a breeze. I understand what people are saying about not enough support around the back to protect from the radiator getting pushed in like a radiator brace would do but I dont see that happending anyway becuase it is bolted to the shroud.
I think these guards were desinged to protect form a side impact and also to keep sticks and debris from puncturing the radiator from the front. I will go on record saying that these guards will perform these functions very well.
The fit was ok. The guards themselves fit nicely around the radiators and are braced well so they dont fold in on themselves. The only problem comes from the lower bolt on the shroud that originally bolted into the louver but now bolts into a supplied bracket. In order to reach this bracket with the lower shroud bolt I had to bend the bottom of the shroud about 1 inch (or trim the inside or the shroud which I chose not to do). I dont know how this could have been avoided becuase the original fit between the rad and the shroud was so tight.
So now the outer edge of the shroud bows from top to bottom a total of about 1 inch from stock at its widest point. The difference is almost unnoticeable by eye but I took lots of pictures before and after and during so stay tuned. I will post them up monday (I am going to the trade show in Indianapolis this weekend!!! www.dealerexpo.com).
I have not seen any other iterations or guards for the 06 yet and I dont know how the manufacturers will tie these things into the frame without a big goofy brace unless they use one like roosterperformance does that goes along the front of the frame.
Andy
  • 2012 450 xc-w
Posted February 17, 2006 - 07:44 AM
I purchased, installed and returned a set for my 06. Fit was crappy and they did make the bottom of the radiators at least 1" wider on each side, maybe more!
  • mtrdrms
Posted February 17, 2006 - 08:04 AM
The bottom of the rad shroud is actually dimensionally the same, its about 3-8" above the bottom that bows out a bit. Maybe you installed incorrectly. :thumbsup:
  • 642MX
Posted February 17, 2006 - 04:55 PM
I think there is a lot of faulty installations going on here.
  • riderman329
Posted February 17, 2006 - 05:04 PM
were are you guys getting these at and are the pic?
  • jecsr
Posted February 17, 2006 - 06:09 PM
I ordered mine and the package stated for a 00-02 YZ426F. They made my shrouds bow out quite a bit and you could really notice it when riding. After I trimmed the shrouds, they seem to fit ok now. Since I bought this bike used and it came with black plastics, I was thinking that they might be from a 250F (which should be the same) and perhaps this could be my problem. However, after reading other people having the same issues, it must be the guards. :thumbsup:
  • Norman
Posted February 17, 2006 - 07:12 PM
Guess I should have stated my bike is an 06. I had them on my 00 426 and they did flare the shrouds out. Fit on my 06 was fine, I just was surprised at the lack of bracing.
  • Hot  113 replies
  • Hot  30 replies
