accel pump (need quick response!!!)
1 reply to this topic
  • higgy426
Posted September 21, 2001 - 03:34 PM
01 wr 426
Problem: The accel pump doesn't seem to be working properly. I took apart cleaned.
no better.
I took a long screw driver and pushed on it while i blirped the throttle and I had immediate response instead of a gasping out ready to die please don't do that again response. lil help please!!!!
  • Hick
Posted September 21, 2001 - 06:48 PM
Pushed on what?
Took apart what?
In some cases dirt gets into the passage where the actuating rod sits in the carb body and creates enough of an obstruction to prevent the spring that operates the pump (wrapped around the slide pulley) from being able to push the rod and actuate the pump.
When this happens you need to remove the rod and clean the passage. Smoothing up the rod with some emery paper also helps.
